Go to Post ChiefDelphi is talking about women's clothing. What a time to be alive. - Karibou [more]
Unread 12-11-2010, 14:49
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
BaneBots P80 Gearbox
Have any of you had any problems using this gearbox? Are there any other dual off the shelf CIM gearboxes available?
Thanks,
V
Unread 12-11-2010, 15:09
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: BaneBots P80 Gearbox
AndyMark has a few.
Hi!
Unread 12-11-2010, 15:19
Team 263 has used the Banebots for years and swears by them.
Unread 12-11-2010, 16:09
Cad Master K Cad Master K is offline
AKA: John Keyzer
FRC #2358 (Bearbotics)
Cad Master K is an unknown quantity at this point
Team 2358 has used them for skid steer, Omni and Mecanum and have never had an issue, they are awesome.
"We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard..." John F. Kennedy
Unread 12-11-2010, 16:37
Chris is me's Avatar
AKA: Pinecone
The P80 has its uses, but you need to be careful to not use them to support a cantilevered load and to not exceed 85 ft-lbs of torque in any application. On the other hand, AndyMark gearboxes can take all kinds of abuse. Given the choice I'd use an AndyMark product every time, but if your design calls for a P80 it can be used.
Don't cantilever them.
Unread 12-11-2010, 18:52
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We learned this the hard way last year.
A few of the higher ratios are capable of exceeding 85 ft-lbs of torque by a factor of 4 or more when a CIM is stalled. (calculations show that we may have put as much as 400ft-lbs of torque through a 256:1 gearbox)
For drive stuff they're alright, especially if you're not running high traction wheels and they seem useful for some manipulators as well, but if you even think you may exceed the 85 ft-lb warning you should look elsewhere...
-Dustin Benedict
Unread 12-11-2010, 19:57
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
we have used them and they work alright, the mounting holes are a huge pain though as the plates to support them must be accurate to .001 or they wont fit right.
Unread 12-11-2010, 21:42
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We have used Banebots trannys for all kinds of applications: drive trains, manipulators, everything. We even used the first generation in a dual cim drive train application and they worked flawlessly. We have always supported the output shaft when we kept the shaft at its full length. We have also cut the shaft to size and have used it unsupported. For spaces with short vertical clearance, they work very well. We haven't had the same issues with tight tolerances on mounting plates either. All our pieces are made with hand tools and a drill press. I'm pretty sure we aren't anywhere near +/- .001
Unread 19-11-2010, 17:11
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
the standard toughboxes can use 2 CIMs
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Banebots P80 Key Dimensions Spirator Technical Discussion 3 28-03-2010 10:16
Banebots P80 Spirator Technical Discussion 1 13-02-2010 22:09
Banebots Gearbox team691 General Forum 5 03-02-2009 23:26
New Banebots p80 Improvements Madwolvez Technical Discussion 14 04-05-2008 23:22
42 mm Banebots Gearbox Hunter Motors 9 13-01-2007 21:52
