Go to Post In the encyclopedia of FIRST under the term Encyclopedia it says - See Joe Ross. - rees2001 [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 12-11-2010, 23:11
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
How much Calculus?
How much to engineers actually use calculus? What is the proportion of Non-Calc vs. Calc computations?
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 12-11-2010, 23:18
EricH EricH is online now
Re: How much Calculus?
Depends what you're working on.
If you're dealing with motion, you'll be using it quite a bit (position-velocity-acceleration). MEs deal with motion a lot...
Controls and circuits use Differential Equations quite a bit; that's only learned after Calculus 2.
Statics and solid mechanics tend to use integrals and the like sparingly.
As far as proportion, it depends on what you're dealing with. You could probably get through 2 years in college without much calculus, but beyond that, expect about 25-30% of the work to involve calculus in some way, shape, or form; you might even be turning differential equations into algebraic equations.
Unread 13-11-2010, 04:13
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
You could probably get through 2 years in college without much calculus, but beyond that, expect about 25-30% of the work to involve calculus in some way, shape, or form.
Results may vary.
At my school, they start you with calculus your very first semester and start applications of it the second semester. I suppose those are all just "math" or "physics" courses rather then actual "engineering" courses but they are required to be taken first at my college. To the best of my knowledge, there are two general approaches to the engineering degree. Some like to throw a bunch of theoretical math at you so that your engineering courses can go into more depth. Others like to save alot of the theoretical math until half way through so you already have real world examples they can use within the math course themselves.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 13-11-2010, 13:07
Same with mine. Like I said, for about the first two years (while you're still in Calc 1, 2, and 3 and Diff. Eq.), you can probably get by with very limited calculus (physics, some other stuff). Looking at the ME departmental prerequisites, though, if you don't have Calc 1 and Calc 2, there are three courses that you won't be allowed to take in sophomore year: Sophomore Design, Dynamics, and Thermodynamics 1. Most of the math that those courses use is algebra or trig or something like that, so you might be able to get by for a while. Once you get up into junior-level courses, though, you need to be able to do calculus or differential equations at any time.
Unread 13-11-2010, 13:29
Chris is me's Avatar
AKA: Pinecone
If you're an engineer[ring student], you'll use calculus frequently enough that you should know it or be able to pick it back up with a little review. I can't think of an engineering discipline that doesn't use it in a lot of what they do.
Unread 13-11-2010, 13:54
Don't be intimidated by calculus.
Check out the first 47 seconds of this video,
and the first 70 seconds of this video,
for one reason why calculus has gotten a bad rap.
Calculus is not difficult to learn and use, especially if you care more about the application (engineering emphasis) than the theory (math major). With all the CAS tools available today (like maxima), all the grunt work (like finding integrals) is gone and it's actually fun.
Unread 13-11-2010, 20:19
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
I teach math and Physics as my day job and moonlight as a robotics coach. I can safely say that "hard" subjects like Calculus and AP Physics B/C become a heck of a lot easier when you have mastered the algebra skills required to get to the applications that are the focus of the respective classes. Don't worry too much about how much calculus is needed. Math is just one tool. Real life problem solving skills are much harder to learn.
Unread 13-11-2010, 21:04
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
I'm an Environmental Project Engineer and I'd say that my calculations are 99% non-calculus. But that's more because I'm implementing systems rather than designing them. But I loved those days of using calculus to determine the design needs for fluid flow and air transport! Math is FUN!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 13-11-2010, 22:03
Best Available Data
FRC #1778 (Chill Out!)
[3rd Aeronautical Engineering Student Perspective]
I haven't walked into a class this semester that didn't use calculus.
That said, you find in engineering that most integrals are too gross (or time consuming) to do by hand. As Ether said, you'll have Mathematica, MATLAB, a calculator, or Maple to actually do the integration. In my experience, you will be expected to know what an integral means, what a derivative is and be able to integrate polynomials and sine/cosine, but that is about it. There will not be a surprise test question asking you to find the volume of some complicated curve rotated about the x-axis.
Engineering is all about assumptions, and you'll find that lots of these assumptions turn integrals into algebra. Probably 80% of my Aerodynamics notes are integrals, but only 30% of the homework is.
Unread 14-11-2010, 00:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
My two cents: I use calculus occasionally, but the most important thing I learned was how calculus works, fundamentally, as I use numerical integration most commonly. I'm a mechanical engineer, FWIW.
Unread 14-11-2010, 15:58
Gdeaver Gdeaver is offline
FRC #1640
With this being the digital age, some study of the matrix math can be very important. Matrix algebra at a minimum and Matrix calculus for those who want a little more pain and suffering. If one develops the ability to deal with N dimensional matrices, solution to complex problems can be easier. Most people are stuck on either a vector or a table. Some can deal with a 3d matrix. Most give up on N dimensional.
Unread 15-11-2010, 08:22
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I've been a practicing mechanical engineer for almost 9 years. I have never directly used calculus or differential equations in real work. I tend to use Linear Algebra quite a bit however.
I'm still glad I learned the math to understand where many of the formulas that I regularly apply come from but in reality I don't use the math directly in my work because I'm not on the heavy analysis side of the work.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 15-11-2010, 15:18
Generator of Entropy
FRC #2973 (The Mad Rockers)
I'm a Mechanical Engineer I use Calculus regularly in my work. Frequently I have to derive my own beam equations for unique situations that aren't available in Roark and that requires differential and integral Calculus. Also impact loads require performing an energy balance which is generally done with Calculus. If I want the moments of inertia of a section I usually just pull it out the CAD model, but if I want it parametric then I need to derive it with Calculus. Sometimes there are easier ways to get the answer but if you want to understand the sensitivity of the answer to variable parameters you really need to derive the equations yourself.
Unread 15-11-2010, 16:20
RMiller RMiller is offline
Taking a Year Off
AKA: Ryan Miller
RMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really nice
Been in process design engineering for refineries for over 2 years now. I don't use calculus myself. However, the computer I work with uses it (and linear algebra) a good amount.
I have friends that are in research that use calc themselves quite frequently. So, it depends on what you are wanting to use the engineering for.
2002-2004: 967 Mean Machine
2006-2008: 1816 Green Machine
2008-2010: 2739 Bucket of Bolts (BOB)
Unread 15-11-2010, 21:11
DonRotolo's Avatar
Back to humble
FRC #0832
After almost 30 years since my EE degree, I can't say I use Calculus much. But then again I was never a design engineer, I have always had positions where I supported existing product. These days I write training for a living.
But having said that, and noting that although I see the beauty in math and how it describes the physical world, knowing and understanding calculus was absolutely essential to my career. You see, in order to support a product (or write training about it) you must understand the design. And for that, you need to know calculus, otherwise you get lost pretty quick.
Some advice I wish I had as a college freshman: If you don't understand it, or are struggling to keep up, ask for help. Sometimes you need to look beyond your professor (there may be a personality difference), but once you find someone who can explain it in a way YOU understand, it gets a LOT easier.
Ball Capacity? How Much is Too Much? And Can You Use It For A Strategical Advantage? thefro526 Rules/Strategy 21 01-02-2009 02:56
How much of a field? StephLee General Forum 11 11-01-2007 23:48
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
How Much? purplehaze357 Off-Season Events 12 17-05-2002 16:04
