Go to Post Maybe Dean Kamen can appear in Levi's advertising? - David Brinza [more]
Unread 12-11-2010, 15:38
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
User Messages from robot to driver station
I have been reprogramming old robots to run in java. I was wondering if the robot can transmit messages back to the user.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 12-11-2010, 15:47
Re: User Messages from robot to driver station
Yes. In LabVIEW you could use the "WRITE USER MSG" function in the WPI Library. I would imagine there's something similar in Java.
Unread 12-11-2010, 17:21
See the DriverStationLCD class
Unread 14-11-2010, 09:32
If you are talking of pre-Crio robots, the answer is yes. In IFI controlleers, you can even use one of the digital ports on the RC to port data back to the OI. It's tricky but it can be done.
Unread 14-11-2010, 09:35
The hard part with the pre-cRIO contollers is they don't support Java.
The IFI OIs also display a user byte of information from the robot code.
Unread 15-11-2010, 10:01
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If direct serialization is used, then streaming messages between any language is very simple. "Serialization" means transforming an object to its primitive types, then transforming those primitive types to a byte array in a controlled fashion. So long as the objects are simple and the encoding/decoding is done properly, any developer can do serialization manually.
Perhaps a better way to do it is via a standardized language, like WSDL or IDL. However, using the standard protocols to go along with those languages isn't possible with any FRC control system that I'm aware of. Instead, WSDL (xml variant) would be compiled on your development machine to its C/C++/Java equivalent classes: each class has an encode() and decode() method that ensures a C object is identical to its Java equivalent. The structure in physical memory will be different at run-time, yet the code can call the same methods and access the same data. For a first-time run through, I recommend that you keep the C/Java objects very simple so they only contain primitive (int/short/long/char[]) types.
Overall, my suggestion is to create a WSDL file, compile it into C/Java equivalents, and then use the C classes on the robot and the Java classes on the display. Call class.encode() on the robot to get a byte array, then send that byte array from the robot to the display via the robot's communications protocols, the class.decode() on the display. There are some more nuances to get it working properly, but this is the fundamental principle that should get you started.
Being able to do this will open up doors in your career. It will enable you to develop brand new features in a new language while still interfacing with legacy systems developed before you were even born. In industrial systems, just because something is 'old' doesn't mean it's outdated.
We were able to interface the CRIO to our own custom "Radar" display in Java on our laptop in 2009 by doing direct serialization. We could see blips of all other robot trailers detected by the camera on our radar display, as well as have active statuses for the battery, sensors, etc. We didn't do well that year since the robot had many mechanical issues, but the display piece was solid.
GitHub
Finding Distance From Driver Station mwtidd Programming 18 05-06-2010 14:48
Driver Station user manual Ether FRC Control System 7 20-03-2010 17:57
Driver Station User Messages Extend Length bearsomg C/C++ 2 13-02-2010 18:58
Need help with Driver Station User Message Jakub Programming 5 18-01-2010 00:40
Programming Digital Inputs from Driver Station spooncwru Programming 8 01-02-2009 13:14
