Go to Post I think that this clearly indicates that 2017 will be the year we finally see 3.63 robots per alliance. - Caleb Sykes [more]
Unread 14-11-2010, 19:05
CIM quiz
A CIM motor is attached to a small dynamometer which exerts a fixed constant load torque of 100 oz-in on the motor shaft. The CIM is directly attached to a 12VDC source (assume no internal resistance) with heavy gauge wire and connectors (assume no resistance). Assume the CIM's specs are exactly as specified in the attached screenshot.
Questions:
1) What is the CIM's speed?
2) What is the CIM's current?
3) How much power (watts) is being input to the CIM?
4) How much power (watts) is the CIM delivering into the load (dynamometer)?
5) How do you account for the difference between #4 and #3 above?
Name:	CIM specs.png
Unread 14-11-2010, 20:08
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: CIM quiz
Spoiler for Maybe:
Spoiler for ???:
~3763.7 RPM
~40.64 Amperes
487.68 Watts in
~256 Watts out
The inefficiencies of the motor (mostly friction) prevent power from being transfered without loss
Unread 14-11-2010, 20:45
Re: CIM quiz
Originally Posted by PAR_WIG1350 View Post
Re-check your output power calculation.
Ponder your answer to #5 a bit more.
Unread 14-11-2010, 23:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: CIM quiz
4. 278.4 Watts
Unread 15-11-2010, 00:23
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: CIM quiz
Heat
Unread 15-11-2010, 00:54
Re: CIM quiz
Originally Posted by davidthefat View Post
Heat
Elaborate a bit more. Heat due to what?
Unread 15-11-2010, 08:55
Re: CIM quiz
If free speed is 5310 RPM and stall torque is 343.4 and the calculated speed is the free speed - reduction in speed due to load then speed = free speed - (rated torque * (free speed/max torque)) or
5310 - (100 oz.in. * (5310/343.4)) = 3763.69 RPM
If stall torque is 343.4 oz. in. and stall current is 133, then the current constant is .3873A/oz.in. therefore current at 3763.69 RPM is the constant * RPM + I min
I= (3763.69RPM * .3873A/oz.in.) + 2.7A = 38.73 + 2.7A = 41.43A
P IN = I * V = 41.43A * 12V = 497.16 W
The conversion factor for oz. in and speed is 0.00074 and Pout = Torque * RPM * conversion factor,
Therefore P out = 100 oz. in. * 3763.69 * 0.00074 = 278.51W
As the lost electrical power is the current squared * motor winding resistance, and R motor is 12V/133A (stall current) = .0902 ohms, then electrical power loss is 41.43A^2 * .0902ohms = 154.87W.
If the input power is 497.16W and electrical loss is 154.87 and power out is 278.51W then all other losses amount to 497.16-154.87-278.51=63.78W
These losses are attributable to bearing friction, brush friction, back EMF, friction of armature with the air, etc.
Unread 15-11-2010, 11:37
Re: CIM quiz
A CIM motor is attached to a small dynamometer which exerts a fixed constant load torque of 100 oz-in on the motor shaft. The CIM is directly attached to a 12VDC source (assume no internal resistance). Assume the CIM's specs are exactly as specified here.
Questions:
Solution: Assume that the speed vs torque curve is linear, and use the given load torque (100 oz-in) to interpolate the rpm:
rpm = 5310*(1-100/343.4) = 3763.7 rpm
Solution: Assume that the current vs torque curve is linear, and use the given load torque (100 oz-in) to interpolate the current:
amps = 2.7 + (100/343.4)*(133-2.7) = 40.64 amps
Solution: watts = volts*amps = 12*40.64 = 487.7 watts
Solution: watts = oz_in*rpm/1352.3 = 100*3763.7/1352.3 = 278.3 watts
Solution: The total power loss is 487.7-278.3 = 209 watts. Most of this loss is due to I^2R heat loss in the motor windings. The motor winding resistance is 12/133 = 0.09023 ohms, so the I^2R loss is (40.64)^2*(0.09023) = 149 watts. The remaining loss (60 watts) is due to a combination of motor bearing friction, windage, and motor core losses (hysteresis losses and induced eddy currents).
Now, suppose I open the circuit and insert a 0.1 ohm resistor in series with the motor. Assume that the load torque remains the same, at 100 oz-in, and that the resistor is large enough that it does not overheat.
Questions:
5) Explain any assumptions you had to make to get the answers.
Unread 15-11-2010, 17:00
AKA: Alan Wells
FRC #1350 (Rambots)
Re: CIM quiz
I didn't calculate the output current, I drew a picture of the curve and guessed. That would be why I got it wrong. We haven't learned (much) about angular motion in physics yet
Unread 15-11-2010, 17:02
AdamHeard's Avatar
Lead Mentor
Re: CIM quiz
Do you mean output power?
That can be calculated from torque x speed, give it a shot!
Unread 15-11-2010, 19:45
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: CIM quiz
Well, lets see.... Assuming the motor is mostly linear in performance, The No-Load Current is 2.7 amps, the constant (lets use this) D determining the ratio of current to torque is (64-0)/(27-2.7)= 2.633 oz-in per amp, the no-load 12v speed is 5310 rpm, with it losing (5310-4320)/(64) rpm per oz-in, or 5310-4320/27-2.7 per amp.
Oh, and 5310 RPM per 12 volts equates to 442.5 RPM's per volt.
Based on this:
5310 RPM no load
2.7 amps no load
2.633 oz-in per amp of torque
-15.46 rpm per oz-in torque, or 40.74 rpm per amp
442.5 RPM per volt, no load.
So, lets answer number two first. In order for there to be 100 oz-in of torque, the current applied (which in turn causes the force) must be the same, and I'm hoping this math was done correct before, 40.64 amps.
Which in turn brings us back to #1. The voltage loss across a .1 ohm resistor at 40.64 amps would be equal to V=IR, or .1*40.64= 4.064 volts (can't believe I used my TI-89 on that.)
12-4.064 volts = 7.936 volts left for the CIM motor.
A no load speed would be 3511.68 rpm. Subtracting the torque losses would result in an actual speed of -15.46 * 100 + 3511.68 = 1965.68 RPM.
Number 3: Power input to the CIM = VI= 7.936 V * 40.64 amps = 322.5 watts.
Numbah 4: Power output, mechanical: Speed * Force. 1966 RPM * 100 oz-in ~ using a random converter = 100 oz *.278N per oz* (32.76 revs * 2 pi inches * .0254m/in) per sec = OMG = 145.3 ? Watts.
Number 5: I believe I had to answer the second question first. You don't have to, but it eliminates a few extra steps of variable making.
Unread 15-11-2010, 21:00
Re: CIM quiz
Originally Posted by theprgramerdude View Post
Well, lets see....
Nicely done
Now some food for further thought.
In the first scenario, the motor is generating 100 oz-in of net torque (against the external load) plus torque losses at 3764 rpm (due to friction and windage).
In the second scenario, the motor is generating 100 oz-in of net torque (against the external load) plus torque losses at 1965 rpm (due to friction and windage).
In the second scenario the torque losses are less (due to the lower rpm). Therefore the total torque is less than the first scenario, and the current required should be slightly less. How much less ?
Unread 19-11-2010, 21:42
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Talking Re: CIM quiz
the mechanical subteam's answer:
speed: go faster!
heat: it makes to much of this
torque: enough to work on accessories, and great for pulling or driving stuff if you put a 12.75:1 gearbox on
current: work with the battery, when run through the tan device
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 19-11-2010, 21:57
AdamHeard's Avatar
Lead Mentor
Re: CIM quiz
speed: go faster!
I would expect more out of a mechanical subteam.
Unread 21-11-2010, 16:01
joek's Avatar
Re: CIM quiz
me too
Bolt quiz Jay H 237 Chit-Chat 5 25-05-2009 10:00
Safety Quiz? morg102 Games/Trivia 1 20-01-2009 13:23
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Gundam Quiz GAT-X105 STRIKE Games/Trivia 3 09-02-2005 17:11
Team Quiz MrsT General Forum 7 02-03-2002 18:54
