Go to Post I'll guess those tie-dyed, numbered balls are used for alliance-partner lotto. :D - Richard Wallace [more]
Unread 10-11-2010, 22:12
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Re: How to rotate camera to target; motor to the angle of the camera
Started looking the code in detail and as expected ran into some trouble.. i have a question.
Can i just remove the gyro from the autonomus independent.vi, because i am going to be using the servos (the gimbal) to get the angle?
Unread 10-11-2010, 22:14
Yes, you can remove the gyro references.
Unread 14-11-2010, 21:02
FRC #1514 (Vikings)
Hi everyone. I finally got time to write some code and i ran into some ... problem . I do not know how to connect the "x and y" axis of the "Rotate to Target" vi to my servo angles. Because what i want the camera to do is, first set the servos to 0 angle, then after 1 mil second keep adding 10 degrees to each servos and rotate the camera to that angle and look for the image.. If i am doing something wrong tell me
I have attached a picture of what i wrote so far below
Whcirobotics
How to rotate camera to target; motor to the angle of the camera whcirobotics NI LabVIEW 0 08-11-2010 18:18
How to get the camera to show images on the dashboard? whcirobotics NI LabVIEW 38 20-02-2010 11:55
How to make the camera search the light instead of only follow when targeted? jesusescobar Programming 4 18-02-2007 16:56
How do I get distance between Camera and the target? sjung9442 Programming 5 27-01-2006 09:44
How is everyone setting the angle for the shooter/camera? waialua359 Programming 6 26-01-2006 21:51
