Error while downloading code into robot
I get an error while downloading the code from netbeans to the robot. The error code comes out as:
C:\Documents and Settings\Developer\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line: C:\Documents and Settings\Developer\sunspotfrcsdk\ant\upgrade.xml:4 0: java.net.SocketException: Socket operation on nonsocket: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(PlainSocketImpl .java:333) at java.net.PlainSocketImpl.connectToAddress(PlainSoc ketImpl.java:195) at java.net.PlainSocketImpl.connect(PlainSocketImpl.j ava:182) at java.net.SocksSocketImpl.connect(SocksSocketImpl.j ava:366) at java.net.Socket.connect(Socket.java:529) at java.net.Socket.connect(Socket.java:478) at java.net.Socket.<init>(Socket.java:375) at java.net.Socket.<init>(Socket.java:189) at org.apache.commons.net.DefaultSocketFactory.create Socket(DefaultSocketFactory.java:53) at org.apache.commons.net.SocketClient.connect(Socket Client.java:162) at org.apache.commons.net.SocketClient.connect(Socket Client.java:250) at com.sun.spot.sdk.tool.ftp.JakartaFtpWrapper.connec tAndLogin(JakartaFtpWrapper.java:37) at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(Upgr adeTask.java:114) at org.apache.tools.ant.UnknownElement.execute(Unknow nElement.java:291) at sun.reflect.GeneratedMethodAccessor149.invoke(Unkn own Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.tools.ant.dispatch.DispatchUtils.execut e(DispatchUtils.java:106) at org.apache.tools.ant.Task.perform(Task.java:348) at org.apache.tools.ant.Target.execute(Target.java:39 0) at org.apache.tools.ant.Target.performTasks(Target.ja va:411) at org.apache.tools.ant.Project.executeSortedTargets( Project.java:1397) at org.apache.tools.ant.helper.SingleCheckExecutor.ex ecuteTargets(SingleCheckExecutor.java:38) at org.apache.tools.ant.Project.executeTargets(Projec t.java:1249) at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java :442) at org.apache.tools.ant.taskdefs.CallTarget.execute(C allTarget.java:105) at org.apache.tools.ant.UnknownElement.execute(Unknow nElement.java:291) at sun.reflect.GeneratedMethodAccessor149.invoke(Unkn own Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.tools.ant.dispatch.DispatchUtils.execut e(DispatchUtils.java:106) at org.apache.tools.ant.Task.perform(Task.java:348) at org.apache.tools.ant.Target.execute(Target.java:39 0) at org.apache.tools.ant.Target.performTasks(Target.ja va:411) at org.apache.tools.ant.Project.executeSortedTargets( Project.java:1397) at org.apache.tools.ant.Project.executeTarget(Project .java:1366) at org.apache.tools.ant.helper.DefaultExecutor.execut eTargets(DefaultExecutor.java:41) at org.apache.tools.ant.Project.executeTargets(Projec t.java:1249) at org.apache.tools.ant.module.bridge.impl.BridgeImpl .run(BridgeImpl.java:281) at org.apache.tools.ant.module.run.TargetExecutor.run (TargetExecutor.java:539) at org.netbeans.core.execution.RunClassThread.run(Run ClassThread.java:154) can anyone provide help or tips |
| No Robot Code After downloading Code | tutkows1 | FRC Control System | 2 | 08-02-2010 00:51 |
| Code error with while loops?? | Lakeeffect1674 | Programming | 6 | 09-03-2008 13:19 |
| Code error causing robot to go into programming mode. | MJD | Programming | 14 | 30-10-2007 14:21 |
| Wild motors while downloading | GlennGraham | VEX | 2 | 22-09-2006 19:52 |
| Code error on RC after downloading "bells and whistles" version of Kevins camera code | DanDon | Programming | 6 | 10-01-2006 18:07 |
