Go to Post STEM: Science, Trial, Error, Math. - hrench [more]
Unread 15-11-2010, 20:47
kibbs425 kibbs425 is offline
AKA: Kyle Henry
FRC #0125 (Nutrons)
kibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to behold
Send a message via AIM to kibbs425
Re: pic: Broken Output Shaft
No FEA is necessary. Contrary to popular belief. A lot of good analysis can be done with a book, pencil and a napkin! All good ME design books will have a reference to Stress concentrations. They are generally relatively simple to use as long as you can read a chart.
Engineers edge (www.engineersedge.com) is the 1st pass that I usually take when I'm looking and I don't have my book handy and the internet is available. Here is the section on stress concentrations: http://www.engineersedge.com/calcula...tion-shaft.htm
This won't give you the stress unless you know the rest of the numbers, but you can at least compare Kts for the known geometry to determine what has less of an impact.
Shigley's Mechanical Engineering Design is my text book of choice. It was required in my college ME Design class. It is still something that I use regularly and has a lot of great references.
Good luck!
Since 2002
Gearbox Output Shaft Defect Nathan2974 General Forum 2 16-01-2010 10:26
roll pin into output shaft m1k3 Kit & Additional Hardware 18 15-01-2008 16:18
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
