Go to Post The Championship is not always about bringing the robot...it's about learning, experiencing, and celebrating FIRST. - Jessica Boucher [more]
Unread 16-11-2010, 14:27
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
[FTC]: Lubricants
Has anyone used lubricants on your robots in the past? and do you have any tips about them? Also R5a8 says we can use permatex super lube, but is there anything else we're allowed to use, liek graphite.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 16-11-2010, 16:26
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
Re: [FTC]: Lubricants
I think we're limited to the materials they allow, but, in this case, that's fine because the permatex super lube works well.
SAY-WATT.ORG
Unread 16-11-2010, 18:34
jamie_1930's Avatar
Team Role: Student
It's not the matter of permatex being a good lubricant or not it's that I want to be able to just go out and get it instead of having it shipped here.
Also sorry for the horrible grammar in the first post I was running around all meeting and just typed that up as quick as I could.
2009
2008
Unread 17-11-2010, 10:43
No one wants graphite powder all over their field. Just don't.
Unread 17-11-2010, 23:12
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
But it's so sparkly and pretty.
Back to reality. I can see this being interpreted many ways. <R5>a seems to be a list of restrictions that apply to the use of Tetrix components, a category under which this specific lubricant falls. It doesn't seem to be implying that other lubricants are forbidden, but <R2>h could be interpreted as saying exactly that.
Unread 18-11-2010, 08:02
<R5> Robot construction is constrained to the following:
a. Any part from the TETRIX system with the following constraints:
8. The Permatex Super Lube provided by the TETRIX system may be used only to reduce friction with the Robot. Lubricants shall not be allowed to contaminate the playing field or other Robots.
I would interpret that to say only Super Lube may be used and only to reduce friction on the robot. Emphasis mine.
[FTC]: 2009-2010 FTC World Championship - What do you think? Abra Cadabra IV FIRST Tech Challenge 5 29-04-2010 09:00
[FTC]: FTC Futures Forum at FTC World Championship gdo FIRST Tech Challenge 0 08-04-2009 18:46
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
