Go to Post Yes, you are correct. Even when all other databuses are totally out of bandwith, the PainInTheCalf Bus gets top priority. Good thinking ;-) - Joe Johnson [more]
Unread 17-11-2010, 21:29
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
Driver station software
Hello everyone, the last week unfortunately we were robbed our netbook with a joystick in a presentation, now we need to do an exposition for get sponsor but we haven't the netbook and the robot is not working now, I need to know how or what I need for install the driver station in my laptop, if someone could help us with the software
Thank you very much
Unread 17-11-2010, 21:59
Re: Driver station software
The driver station SW will run fine on another Windows computer. It is best to install on an XP installation, but I've run it on Vista and Win7. Note that Win7 in particular will require you to run the DS as administrator. You may also need to set the networking IP of the laptop by hand.
If you see any odd issues, please don't hesitate to ask.
Greg McKaskle
Unread 18-11-2010, 08:03
The software installation package good for any PC is at: http://joule.ni.com/nidu/cds/view/p/lang/en/id/1535
Unread 18-11-2010, 13:02
frcchile's Avatar
FRC #2576
Thank you guys, I installed but is missing some DLL, nivision.dll, nivissvc.dll, etc.
Where can I find the missing DLL???
Thank you!
Unread 18-11-2010, 13:11
Here's a description of that problem.
You can uninstall & reinstall the Driver Station or you can put nicyapi.dll into the C:\Windows\System32 folder
Unread 19-11-2010, 15:37
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
It seems like that is a separate issue Mark. I believe the DLL's frcchile mentioned are part of the LabView runtime(which the driver station software does require). After the LV runtime gets installed, the nicyapi.dll issue will probably also show up, but I believe it's a different issue than the one mentioned.
-Fletch
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 19-11-2010, 20:07
Two of the dlls are used by the dashboard, for vision, and the third is for cypress first touch. If you don't care about the dashboard, change to a remote dashboard, or in the ini file, change the path to the exe.
Greg McKaskle
Custom Dashboards and the Driver Station Software slavik262 Programming 17 02-04-2010 01:20
Can't get cRIO to connect to Driver Station Software greatman05 FRC Control System 2 13-02-2010 22:33
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
driver station corps FRC Control System 5 06-08-2009 20:44
Software Driver? Dave_Lu VEX 3 20-11-2006 15:45
