Go to Post We also use CAD heavily. Cardboard Aided Design. Which is considerably more accessible and intuitive to most students than the other CAD. - JamesCH95 [more]
Unread 15-11-2010, 09:51
RoboElite640 RoboElite640 is offline
FRC #0640
RoboElite640 is an unknown quantity at this point
Error while downloading code into robot
I get an error while downloading the code from netbeans to the robot. The error code comes out as:
C:\Documents and Settings\Developer\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line:
C:\Documents and Settings\Developer\sunspotfrcsdk\ant\upgrade.xml:4 0:
java.net.SocketException: Socket operation on nonsocket: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl .java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSoc ketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.j ava:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.j ava:366)
at java.net.Socket.connect(Socket.java:529)
at java.net.Socket.connect(Socket.java:478)
at java.net.Socket.<init>(Socket.java:375)
at java.net.Socket.<init>(Socket.java:189)
at org.apache.commons.net.DefaultSocketFactory.create Socket(DefaultSocketFactory.java:53)
at org.apache.commons.net.SocketClient.connect(Socket Client.java:162)
at org.apache.commons.net.SocketClient.connect(Socket Client.java:250)
at com.sun.spot.sdk.tool.ftp.JakartaFtpWrapper.connec tAndLogin(JakartaFtpWrapper.java:37)
at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(Upgr adeTask.java:114)
at org.apache.tools.ant.UnknownElement.execute(Unknow nElement.java:291)
at sun.reflect.GeneratedMethodAccessor149.invoke(Unkn own Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.tools.ant.dispatch.DispatchUtils.execut e(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:39 0)
at org.apache.tools.ant.Target.performTasks(Target.ja va:411)
at org.apache.tools.ant.Project.executeSortedTargets( Project.java:1397)
at org.apache.tools.ant.helper.SingleCheckExecutor.ex ecuteTargets(SingleCheckExecutor.java:38)
at org.apache.tools.ant.Project.executeTargets(Projec t.java:1249)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java :442)
at org.apache.tools.ant.taskdefs.CallTarget.execute(C allTarget.java:105)
at org.apache.tools.ant.Project.executeTarget(Project .java:1366)
at org.apache.tools.ant.helper.DefaultExecutor.execut eTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.module.bridge.impl.BridgeImpl .run(BridgeImpl.java:281)
at org.apache.tools.ant.module.run.TargetExecutor.run (TargetExecutor.java:539)
at org.netbeans.core.execution.RunClassThread.run(Run ClassThread.java:154)
can anyone provide help or tips
Unread 18-11-2010, 19:13
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Error while downloading code into robot
ummmm.... why java?
and for the answer- try to find a veteran team or professional programmer to look over your code
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 18-11-2010, 19:58
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
I'm not as familiar with Java as with C++ or LabVIEW, but I think it's an issue with the connection to the robot for uploading code, rather than one with the code. The upgrade script updates the code on the robot with the current Java code, and "Socket operation on nonsocket" indicates an issue internal to the Ant script, though it may indicate a misconfiguration of the script.
No Robot Code After downloading Code tutkows1 FRC Control System 2 08-02-2010 00:51
Code error with while loops?? Lakeeffect1674 Programming 6 09-03-2008 13:19
Code error causing robot to go into programming mode. MJD Programming 14 30-10-2007 14:21
Wild motors while downloading GlennGraham VEX 2 22-09-2006 19:52
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
