You infrared my mind.
Unread 18-11-2010, 21:52
hans4's Avatar
hans4 hans4 is offline
AKA: Nick H
FRC #2002
hans4 is an unknown quantity at this point
festo valves
So I'm sorry if I'm reposting, but i cant seem to find this anywhere, where do you buy the FRC Festo valves? i searched through the Festo online catalog and was unable to find it.
Anyone have a link?
thanks in advance
Unread 18-11-2010, 22:07
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: festo valves
Nick,
If it doesn't matter what brand of solenoids you need.
http://www.chiefdelphi.com/forums/sh...=smc+solenoids
I would buy some SMC ones, I've been much happier with them than the festo ones. Not sure on price difference, but if you need it for FRC use it shouldn't matter if you use SMC or the festos.
-RC
R.C.
MadTown Robotics Team 1323
Unread 18-11-2010, 23:55
hans4's Avatar
AKA: Nick H
FRC #2002
Re: festo valves
Thanks RC
I'm a little confused as to which of those parts i need for the double. one says mandatory and one doesn't and there is no change on the displayed picture in the sites. any insight?
once again thanks for the help
Unread 19-11-2010, 02:50
R.C.'s Avatar
Re: festo valves
Sorry for the confusion:
Solenoid: SY3240-6H
http://www.pneuaire.com/sy3240-6h.html
Manifold: SY3000-27-1T (Mandatory)
http://www.pneuaire.com/sy3000-27-1t.html
For every solenoid you need one manifold (unless you buy a one gigantic manifold). So both are necessary to make a double solenoid work.
-RC
R.C.
Unread 19-11-2010, 09:35
hans4's Avatar
AKA: Nick H
FRC #2002
Re: festo valves
ah thanks for the clarification!
Nick
Unread 20-11-2010, 22:32
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: festo valves
I seem to remember that the Festo valves were a special model provided to FIRST, or perhaps a discontinued model, and we were told they were not available for extra purchase.
Unread 24-11-2010, 16:38
hans4's Avatar
AKA: Nick H
FRC #2002
Re: festo valves
Okay so those solenoids are back ordered for four weeks would these replacements work?
SY3240-3G:
http://www.pneuaire.com/sy3240-3g.html
SY3240-3GZ:
http://www.pneuaire.com/sy3240-3gz.html
or perhaps
SY3240-3L:
http://www.pneuaire.com/sy3240-3l.html
SY3240-3LOZ:
http://www.pneuaire.com/sy3240-3loz.html
these are from the same distributor but would these work as replacements or do we need to wait out the four weeks?
Also what is the true difference between a single and double solenoid? I cant seem to find that information anywhere.
Nick
Unread 24-11-2010, 17:32
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: festo valves
SY3240-3G:
SY3240-3GZ:
or perhaps
SY3240-3L:
SY3240-3LOZ:
These will NOT work on an FRC robot. These are rated for 110VAC operation.
12v solenoids from SMC have 6 in the first character of the second group of their part number, for example VQZ2221-6LO-N7T.
Single acting solenoids have their output directly controlled by the input; thus, when the power is turned off or disabled, the output returns to the "off" output no matter what. Double acting solenoids only change their output when the input signals are toggled; thus they can maintain either output with a loss of signal.
Art Dutra IV
世上无难事,只怕有心人.
Unread 24-11-2010, 18:15
jspatz1's Avatar
AKA: Jeff
Re: festo valves
Another way to describe single vs. double solenoid: Single solenoid valves are actuated by the solenoid, but are spring loaded to return to the normal state when the solenoid is off. So they will actuate only while the solenoid is energized, and will return to normal state when power is off. A double solenoid is solenoid-driven in both directions, and has no spring. Either solenoid is energized to actuate the valve into either state. The valve will remain in the last state, even without power, until it is electrically or manually changed.
Unread 24-11-2010, 20:06
hans4's Avatar
AKA: Nick H
FRC #2002
Re: festo valves
alright thanks for the help guys!
we decided to go with buying a couple of the single solenoids as they were in stock. My team has always used the doubles so this will be an experiment.
Thanks for the help and quick responses everyone!
Nick
new festo valves caincteam2777 Pneumatics 36 17-02-2011 13:28
Multiplex Festo Valves C3PO Pneumatics 27 03-03-2010 07:46
2009 Festo Valves in 2010 mjgard Pneumatics 3 30-01-2010 16:33
How do I use the pneumatic Festo valves? mynameisbob Pneumatics 15 17-01-2009 18:10
2 FESTO valves on 1 spike bhsrobotics1671 Electrical 12 08-02-2008 13:37
