Thread Tools |
Rating:
Display Modes |
#14
Re: Lathe Cart? (NY/NJ/PA)
Hi
"The idea would be to make a frame custom to the lathe with wheels on the bottom and a tool chest with all the required tooling mounted under the lathe." - It is a great idea and works if built right I set up my lathe (9"x36" atlas) in the same fashion as decribed using a steel plate 3/4"x24"x60" as a top and a detacable angle iron frame and HD locking casters I mounted a "side box" to the frame and still have room for a rollaway too. I drilled 4 holes in the top plate for eye bolts at the CG point to lift it with a cherry picker for easy transport without dismounting the lathe the system works great and is ridged and stable it has been to AZ and NV regionals and transported to many shops over the years I also did a drill/mill like this when the team was homeless and we had to move equipment around and setup shop on a daily bases Have fun! Geo. |
| Mill or Lathe... | nnfuller | Technical Discussion | 32 | 16-06-2010 22:16 |
| pic: 1029 cart - Rene de Cart | bjimster1 | Extra Discussion | 6 | 03-03-2007 20:47 |
| Good deal on a lathe? | sanddrag | Technical Discussion | 7 | 25-02-2005 23:02 |
| Can this be turned on a lathe? | sanddrag | Technical Discussion | 8 | 02-02-2004 19:10 |
| Grizzly Lathe Opinons | Caroline | General Forum | 7 | 28-08-2002 18:55 |
