Go to Post If all goes well (cross fingers) we'll have a joystick for driving and one - count it, one - button: FIRE - DonRotolo [more]
  #61   Spotlight this post!
Unread 17-11-2010, 14:08
Re: yes comunication, yes code but no response by robot
Originally Posted by DaBossToss View Post
i know i under stand the set up...
You aren't giving a clear indication that you do understand it. For example:
and do have the sidecar connected to the Crio in module in slot 2 to PWM to the Crio
Greg just told you that the Digital Sidecar should be connected to the module in slot 4.
but do you understand what soket exception:Connection reset in netbeans and failed to connect to target server in c++.
It tells me that the computer you are using is unable to establish a network connection with the cRIO. There could be problems with the physical network (a faulty patch cable or broken ethernet connector, for instance), or one or more of the devices on the network could have a misconfigured address. It is also possible that you have multiple network interfaces enabled, and Windows is unable to determine the proper path to talk to the cRIO.
When you formatted the cRIO, what team number did you give it?
What is the IP address of the computer you are using to try to communicate with the cRIO?
Can you tell us exactly how your network is wired, describing where each cable is connected?
  #62   Spotlight this post!
Unread 18-11-2010, 11:42
DaBossToss's Avatar
DaBossToss DaBossToss is offline
FRC #1318 (IRS)
DaBossToss is an unknown quantity at this point
gave it 1318 as team number.
10.13.18.7 is the laptops ip adress.
it is a direct connection from our laptop to the router and a direct connection between the router and the cRIO and a direct connection between our netbook and the router.
and btw we can ping the cRIO.
  #63   Spotlight this post!
Unread 18-11-2010, 15:32
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
When you say netbook, are you referring to the Classmate given out by FIRST that is used as the Driver Station?
If so, can the Driver Station see the robot?
This can be determined by connecting everything as you said you had it, then looking at the circles in the bottom left of the driver station, one of them says "Connection" or something similar. This circle will be bright green if the Software can see a cRIO.
Is it bright green?
  #64   Spotlight this post!
Unread 19-11-2010, 11:46
DaBossToss's Avatar
FRC #1318 (IRS)
yes the it is the classmate and it can communicate with the cRIO.
  #65   Spotlight this post!
Unread 19-11-2010, 12:16
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
You said you're using Java.
When you open the cRIO re-imager, what language does it say the cRIO is formatted for?
(LaVIEW, C++, or Java?)
-- Marshal Horn
  #66   Spotlight this post!
Unread 02-12-2010, 11:53
DaBossToss's Avatar
FRC #1318 (IRS)
java
  #67   Spotlight this post!
Unread 02-12-2010, 22:37
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
did you feed the watchdog?
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Multidirectional Wheels Yes or No?? LordBritten Kit & Additional Hardware 2 02-10-2005 19:15
Guestbooks on websites? Yes or No? Elgin Clock Website Design/Showcase 17 07-09-2004 18:28
YES, so happy! Tton General Forum 10 19-11-2003 21:55
3d community... yes or no? JabzX 3D Animation and Competition 23 25-03-2003 17:23
