Thread Tools |
Rating:
Display Modes |
Re: Kinect LabView Drivers
They do? The NI 9074 I have at work (purchased less than 3 months ago) does not...
Check this one out: http://tinyurl.com/2bjsqx7
Either way we should look for a solution with the DIO board since that will probably be the most natural interface to work with when wiring up the Kinect. It would actually probably be pretty easy to put together a tutorial on creating a male usb to the individual power wire and the I/O wires that can be connected to the Kinect. Could be as simple as buying the Kinect legacy extension from Fry's or the like, and cutting off the ends of the wires, stripping them, and wiring them appropriately. Last edited by Ryan Gordon : 20-11-2010 at 06:15. |
On the USB subject, the cRIO family has lots of variety, and some have a USB port. Last I checked, the USB stack exclusively supported the storage protocol. It was used to provide a file storage interface to a USB stick.
True, drivers for other device types could be written, but doing so for VXWorks and keeping the RT aspects in mind are not so easy, so the other device types will not be supported unless there is a good reason for NI to purchase or build the necessary drivers. I wouldn't really worry about the USB issue though. Exploring and learning about the kinect using a laptop sounds like an incredibly beneficial journey. Please keep it up. And if you are interested in sharing your results, please consider also posting them to NIWeb as you may get a good number of power users interested. Greg McKaskle |
I've attached my source code here even though it doesn't have depth or camera data working yet. I've certainly learned a lot from this experience, it's been really rewarding. I'll probably end up changing it all up to use a dll generated from the https://github.com/OpenKinect/libfreenect/ library. LabView doesn't have isochronous USB support so that will be necessary in the end anyway but I wanted to see how far I could get with the raw VISA interface. To setup the Kinect to your PC using the labview libraries you'll need to use the VISA Driver Wizard to create a NI-VISA driver for the Xbox NUI Motor and Xbux NUI Camera. Audio isn't necessary since at the moment it hasn't been reverse engineered yet. Once that's been done it's as simple as open up core.vi and running it. If the Kinect is working and the driver was setup right it will autodetect the usb port it's running on and initialize the motor and accelerometer, etc. http://ryangordon.net/libfreenect.zip Uploading isn't working here for some reason. |
You could theoretically program the FPGA on the cRIO to act as a USB host, and from there, you could control the Kinect. I haven't actually tried it, but it seams feasable.
The FPGA could theoretically implement the host controller features, but you would still need a USB phy (physical layer interface) to host the USB electrically. Also, the host controller is terribly complex and not really a reasonable engineering approach. You would be far better off using a device that already has a USB host controller (such as the cRIO 9022 mentioned earler, a laptop, a TI Beagle Board, or even a Luminary (now TI) Stellaris part with USB OTG support).
#7
![]() I've got the LabView drivers fully working but still not completely stable yet. The dlls that run behind the scenes still need a lot of polishing but this is a great start so far. The next big challenge will be to find a reliable/easy way to get the Kinect to run through the cRIO as we wait for the dlls to stabilize. I'll hopefully have the development source code up in my github repository within the next weeks. Cheers, Ryan Last edited by Ryan Gordon : 26-12-2010 at 04:21. |
#8
Aside from getting the data into the c-rio, there is the raw computational power of doing anything useful with the data. Wouldn't a better strategy be getting the data back to the driver station lap top and do the processing there?
A 400 mhz power pc vs. a dual core x86? The c-rio could be by passed completely. A usb host controller interfaces to the kinect and then sends it by lan to the gaming router back to the laptop. First would have to change the ruling on no lasers. I believe the Kinect has a true infrared laser. The kinect could have tremendous affect on our robots in the future. You may want to keep an eye on Microsoft's robotic studio. Word has it they may be releasing some drivers. |
#9
The laser is a Level 1 Class laser but it's perfectly safe as there is a million safety features that PrimeSense and Microsoft built in to make sure it stays safe.But the showstopper here is that there is too much interference with multiple Kinect's moving around. I'm just building this so I can make a robot do things by itself autonomously; The idea of true autonomy is very poorly implemented in FIRST, mainly because the complexity and lack of technology to make it more plausible. I quite think this would help others interested in exploring truly autonomous robots. Every year that passes by goes more decommissioned pieces of metal that never get put into competition again and I quite think this would make for some interesting projects with those old robots. That is certainly what I'd like to do off-season with them. Last edited by Ryan Gordon : 28-12-2010 at 20:17. |
#10
I am EXTREMELY interested in this. Do you plan on releasing it when its done?
#11
Hi, this has grabbed my interest. I believe that LabVIEW does support isochronous connections. Although I could only find documentation on Firewire and isochronous data transfer, I have successfully used every USB webcam that I have tried with LabVIEW. The IMAQ USB drivers have to be installed. They are available to download from NI, but, I am unsure of any licensing. (I think only the NI Vision module has to be activated, not the drivers) If the device can be enumerated via USB devices, it should work via IMAQ USB capture.
#12
I previously tried using the VISA interface for USB capture which doesn't support isochronous transfers.Quote:
#13
This is the XboX 360 kinect or am i thinking wrong?
#14
Hello all.
LabVIEW VISA USB does not support isosynchronous communications. This is stated in documentation describing how to install a RAW USB driver for low-level USB device communication. The easiest way to use the kinect with LabVIEW is to have it be recognized as a USB camera, and acquire the image data via IMAQdx. I've manged to get this working in the last couple of days, and will be posting a tutorial video on how to get there, as it's a bit involved, especially if you've been playing with all of the other kinect drivers out there from CL, OpenKinect, and PrimeSense. Of course this limits you to using a PC running Windows OSes, so not really applicable to cRIO integration. |
#15
I could see someone getting a Kinect running on a robot using a mini-ITX motherboard with a SSD drive. Another option would be to get it running on a microcontroller. I will likely be working on using the Kinect with a Luminary Micro 3000 series chip at work sometime in the next few months, but I'm not certain I will have anything there before kickoff. |
| M$ Kinect controlling robots! | basicxman | FRC Control System | 28 | 17-11-2010 23:33 |
| Using Kinect to Design Your Robot | JesseK | General Forum | 6 | 17-11-2010 13:03 |
| Drivers | JulieB | General Forum | 22 | 03-02-2005 13:23 |
| drivers | esellers | Rules/Strategy | 5 | 24-01-2003 08:46 |
