Go to Post I too can find a method with correlation bias by applying a pattern to most datasets! - BrennanB [more]
Unread 20-11-2010, 01:00
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: pic: Soldering accidents...
Originally Posted by PAR_WIG1350 View Post
(I was aiming for a cup of water but that is a story for another day.)
I'm sure we'd all like to hear that one
Originally Posted by Jeff Pahl View Post
I'm always amazed by the number of people at work that have trouble learning not to solder while wearing shorts...
I really really shouldn't laugh but...
Unread 20-11-2010, 11:18
It only takes once!
Unread 20-11-2010, 12:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Regarding soldering and fire alarms, (such as those found in schools), am I correct in saying that there is no chance of soldering setting off the fire alarm, because they are activated by heat, not smoke?
Unread 20-11-2010, 13:19
You are so not correct. You won't set off a ceiling sprinkler, since those are indeed triggered by heat, but the electric sensors are almost all smoke detectors and will go off.
Smoke detectors are called smoke detectors for a reason. If you are soldering in an area with a smoke detector, you really should be using an exhaust fan.
Unread 20-11-2010, 14:59
Sandy,
People set off smoke detectors all the time if they are working right under the detector and there is no air movement. Most often, the fumes are dissipated quickly enough to prevent false alarms.
Soldering Wires to Motors rsegrest Electrical 14 20-02-2010 01:47
Soldering questions Nathan Electrical 18 11-09-2007 21:55
Crimping/Soldering stevex Electrical 10 01-02-2005 08:32
Human Player Accidents During 10 Seconds SuperDave General Forum 24 06-04-2003 18:36
