Go to Post Don't be in a rush to build a robot until you know what robot it is you need to build. - Chris Fultz [more]
Unread 21-11-2010, 18:02
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Using a DS to control a FRC robot
Hello all.
Inspired by this project: http://roboticjourney.blogspot.com/, me and my team have decided to try and make a Nintendo DS act as a robot base station/control board. I was wondering the following things:
  1. How do we route the video to the ds?
  2. How do we get the robot to interpret the button presses on the ds as raw buttons on a "joystick"?
please reply
Unread 21-11-2010, 18:14
Re: Using a DS to control a FRC robot
Oddly enough, the very first DS was a DS.
That is, the first demo we gave used a Nintendo DS as the Driver Station. The touch screen makes for some really fun driving.
Unread 21-11-2010, 18:19
1 * 4 != 14
can i please have a copy of that code? it would make this project exponentially easier
Unread 21-11-2010, 18:43
This was back before NI officially joined the project, so it is a touch out of date
The protocol is completely different, so it wouldn't really help at all. Not even sure where it is archived.
Cool project though, it should be fun!
Unread 21-11-2010, 19:03
1 * 4 != 14
/me sadface
do you know where the code for the driver station is? preferably in some !labview, but I can *try* to parse it if labview is the only road.
Unread 21-11-2010, 22:27
It is possible to do what you want, but you will not find the path an easy one.
The Driver Station source code is not published. The Driver Station-to-Robot communication protocol is private information. It might be easier to implement your own controller than to figure out how to emulate the FRC Driver Station.
Unread 21-11-2010, 22:44
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Now, you can try to capture the packets being sent and recieved and reverse engineer from that. But honestly that seems like an awful lot of work to do something like that.
Use this to capture the packets:
http://www.ethereal.com/
The easier thing to do is make drivers for the DS on the computer to use as a controller
Unread 22-11-2010, 00:09
1 * 4 != 14
yeah, i'll probably go back to my original idea of using a ds to control an ardubot. thanks for the advice though
Unread 22-11-2010, 00:34
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
After the 2009 season I attempted to reverse engineer the ds-robot, ds-fms, and fms-ds communication. Its not complete, but, IIRC, I had a proof of concept ds which snet static data to the robot.
My work is at http://frc1103dashboard.codeplex.com.
You may find some of it useful.
Eric Haskins KC9JVH
Last edited by EHaskins : 22-11-2010 at 00:41. Reason: fixed url, for real this time
Unread 22-11-2010, 07:55
The protocol isn't that complex, and a soft DS has been written by several people. If you can get the DS to display a jpg, that part will fall into place. The only issue is that this is close to kickoff, but otherwise, a very doable project.
Greg McKaskle
Unread 22-11-2010, 09:11
1 * 4 != 14
I have code that does exactly that, i just have to set the image size to QQVGA(?) (160x120). Where do i send data to get the image to come back?
Unread 22-11-2010, 11:16
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
The contents of each packet are listed in the FRCCommonControlData struct in the NetworkCommunication/FRCComm.h file of the WPILib source. Wireshark (a.k.a. Ethereal) might help with disassembling the packets. I've looked at the packets with Wireshark, but it's hard to extract useful information without a disassembler plugin. Does anyone know why the protocol is supposedly private/closed-source? I would think that FIRST would encourage exactly this kind of innovation.
Unread 22-11-2010, 12:06
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
I've done this, including the Robot->DS direction (which is notably not documented in FRCComm.h), as part of an effort to build a robot side simulator in Python (related to my RobotPy work). So far I have complete functionality of basic robot operation running on Python on a normal PC interoperating with the official DS. Still to be done is enhanced IO, but much of this is documented in the EnhancedIO WPILib headers. I'm planning on completing this, along with implementing a simple non-GUI DS for testing purposes, in the next week or so.
I have not yet published this work, partly because I too am wondering why FIRST has kept the Robot/DS protocol secret, particularly given how easy it is to reverse engineer . I can understand the desire to keep the FMS protocol secret (due to competition network security issues), but not the rest.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 22-11-2010, 19:41
As far as I know, the protocol was not meant to be private, but it is not documented either. Perhaps this is to keep things flexible from year to year. Perhaps there was some concern about safety.
The system watchdog will shut down the robot if the communications halts, but if a badly written DS continues sending enabled packets and ignores the driver, the robot is essentially out of control. Something to keep in mind if building a DS for robots of this size and speed.
Greg McKaskle
Unread 22-11-2010, 20:14
1 * 4 != 14
I'm gonna have it control a servobot over a custom udp protocol
do you know how to grab images from the robot camera over the wireless?
Position Control using potentiometer? biojae CAN 13 03-02-2010 20:12
Using a pot to control speed SL8 NI LabVIEW 13 18-02-2009 17:02
FRC Workshop (Atlanta) - Using Collaboration Software to Jumpstart Your FRC Team PTC_FRC CAD 0 16-04-2008 10:37
**FIRST EMAIL**/FRC Robot Control System Survey Mark McLeod FIRST E-Mail Blast Archive 4 11-09-2007 00:45
Using a switch to control a PWM Max Lobovsky Programming 11 25-02-2004 17:20
