Go to Post [when asked where to learn about robot parts] ...some forum called Chief Delphi. I hear the people there are pretty knowledgeable about this robotics thing. - EricH [more]
Unread 22-11-2010, 21:23
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Re: [FTC]: Lag and Teleop (Labview)
To add to my mentor's post, we also experimented with a vi I found last year on the FTC forums known as Read Packet Flush.vi that replaced the read packet vi, in which it erased the inbox before accepting the next packet (least I think that is how it worked, the help file was a little lacking in the technical aspect). Last year this completely got rid of our lag for competition. This year I tried it with a vi of using only the drivetrain and it worked, however when I add the other code for the rest of the robot the lag seems to return.
My first idea is that the NXT is simply running too much code in each iterative and that it wasn't reading fast enough because of this, but I've seen teams with more complex setups than this, so I find it hard to believe. I understand that LABview is not as commonly used in FTC (least not from who we asked at competition last year), but help would be appreciated. The only idea I have left is run the NXT in two states, one for the first controller functions, one for the second, but i can't imagine this being easy or helping much.
"Don't worry, programming can fix it"
Java in RobotC for FTC TeleOp lmnotran Java 3 30-01-2010 19:03
Teleop Lag Xavier Brandall Programming 14 17-03-2009 18:21
Labview Autonomous AND Teleop Two-Face Programming 1 14-02-2009 18:33
[FTC]: Bluetooth lag? Nick 568 FIRST Tech Challenge 5 12-02-2009 07:49
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
