Go to Post Surely, we've seen enough new and interesting implementations of technology in FIRST that we won't keep limiting our imagination to the tried and true. - Madison [more]
Unread 23-11-2010, 15:47
Re: [FTC]: Lag and Teleop (Labview)
Originally Posted by iblis432 View Post
I have just finished a revised version of how teleop code. I think I've ironed out most of the problems, but I would like to submit it here for review while I'm waiting on a chance to work on the robot.
The zip file contains the revised version known as 0035 teleopstate.vi plus all the subvis. All of the comments and context help data is up to date, and the front panel contains information the vis.
See attached screen shot.
By saving the vi in LabVIEW9, you have significantly reduced the pool of people who would potentially be willing and able to help you.
Name:	LabVIEW error.png
Unread 23-11-2010, 16:02
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
my understanding is that 2009 is the only version of labview you are allowed to use in FTC. I know when FTC first started with 8.5, but after that 2009 was what came in the kits. I have both versions on my computer, and if I have time i'll make a similar one in 8.5 if I find we are still having problems, otherwise I will keep the format in 2009 until I have a significant reason to change it.
"Don't worry, programming can fix it"
Unread 23-11-2010, 16:34
See attached screenshot.
You don't have to manually reconstruct the vi in a different version of LabVIEW.
Just use the "save for previous version" menu item from the File drop-down menu.
Name:	save for previous version.png
Unread 23-11-2010, 18:55
AKA: Bobby
I am not allowed to save it for a previous version because I do not have the password to save certain FTC toolkit vis.
The code was just tested on the robot however, and everything is working perfectly. It is all thanks to the suggestions here. Thanks so much.
Java in RobotC for FTC TeleOp lmnotran Java 3 30-01-2010 19:03
Teleop Lag Xavier Brandall Programming 14 17-03-2009 18:21
Labview Autonomous AND Teleop Two-Face Programming 1 14-02-2009 18:33
[FTC]: Bluetooth lag? Nick 568 FIRST Tech Challenge 5 12-02-2009 07:49
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
