Go to Post Didn't know the details about the battery. In the past it was just a black (grey) box with two terminals...use...recharge...use..recharge. - cbolin [more]
Unread 25-11-2010, 23:19
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Python virtual speed controllers!
Hello all.
I know this should go in the python forum, but this can affect everyone.
here is the code, just put it all in one directory, running directions below:
debug_test.py
#!/usr/bin/python
import cmd
test = None
var = []
def do_args(args):
    print args.split()
def do_driver(args):
    arg = args.split()
    test_passed = False
    if len(arg) > 0:
	var1 = float(arg[0])
	var2 = float(arg[1])
	var3 = float(arg[2])
    else:
	var1 = 0.5
	var2 = var1
	var3 = var1
    try:
	import outputs, testing
	test = outputs.Driver(1,2,3,4)
	print
	print "Doing tankDriveRaw:"
	test.tankDriveRaw(var1, var2)
	print
	print "Doing holonomicDriveRaw:"
	test.holonomicDriveRaw(var1, var2, var3)
	print
	print "testing the fancy list-based versions, tankDrive then holonomicDrive"
	test.tankDrive([0, var1], [0, var2])
	test.holonomicDrive([var1, var2, 0, var3])
	print
	print "Don\'t forget to stop the robot"
	test.stop()
	test_passed = True
    except:
	print "fail"
    if test_passed:
	print "The robot is able to move, test passed"
class tests(cmd.Cmd):
    def __init__(self):
	cmd.Cmd.__init__(self)
	self.prompt = "2412_debug# "
    def do_driver(self, args):
	"""Actually tests the driver class I wrote"""
	return do_driver(args)
    def do_EOF(self, args):
	import sys
	print
	sys.exit(0)
    def do_args(self, args):
	"""A dummy to test variable handling"""
	return do_args(args)
    def do_show(self, args):
	"""A failed show command"""
	arg = args.split()
	if arg[0] == "test":
	    print test
	if arg[0] == "ver":
	    print "Version 0.2, Touko"
	else:
	    for n in var:
		if arg[0] == n:
		    print var[n][arg[0]]
    def do_var(self, args):
	"""Sets variables, can't do much else :("""
	args = args.split()
	if args[0] == "test":
	    test = args[1]
	    print "test case"
	else:
	    var.append({args[0]:args[1]})
	    print "other case"
	print "variable " + args[0] + " set to " + args[1]
    def do_showVars(self, args):
	"""Shows all raw variables"""
	args = args.split()
	for n in var:
	    print n
    def do_prompt(self, args):
	"""Allows you to change your prompt"""
	args = args.split()
	self.prompt = args[0]
    def do_cure_cancer(self, args):
	"""the obligatory easter egg"""
	args = args.split()
	print "sorry, my mentor told me to not make programs cure cancer :P"
main = tests()
main.cmdloop()
outputs.py
#not the main class
try:
    import wpilib as wpi
except:
    import testing as wpi
class Driver:
    def __init__(self, port1, port2, port3, port4):
        self.FL = wpi.Victor(port1)
        self.FR = wpi.Victor(port2)
        self.RL = wpi.Victor(port3)
        self.RR = wpi.Victor(port4)
        self.vicList = [self.FL, self.FR, self.RL, self.RR]
    def stop(self):
        """Stops the robot, useful for everything"""
        self.tankDriveRaw(0, 0)
        print "Robot Stopped"
    def tankDrive(self, stick, stick2):
	left = stick[1]
	right = stick2[1]
        try:
            self.vicList[0].Set(left)
            self.vicList[1].Set(-right)
            self.vicList[2].Set(left)
            self.vicList[3].Set(-right)
        except:
            print "tankDrive at " + str(left) + " and " + str(right)
    def holonomicDrive(self, xboxController):
	power = xboxController[1]  #y-axis, first stick
	strafe = xboxController[0] #x-axis, first stick
	spin = xboxController[3]   #x-axis, second stick (x...[2] is the trigger axis)
        fl = power + strafe + spin
        fr = power - strafe - spin
        rl = power - strafe + spin
        rr = power + strafe - spin
        print "holonomicDrive called"
        self.FL.Set(fl)
        self.FR.Set(fr)
        self.RL.Set(rl)
        self.RR.Set(rr)
    def tankDriveRaw(self, left, right):
        print "tankDriveRaw at " + str(left) + " and " + str(right)
    def holonomicDriveRaw(self, power, strafe, spin):
        print 'holonomicDriveRaw called'
        self.FL.Set(fl)
        self.FR.Set(fr)
        self.RL.Set(rl)
        self.RR.Set(rr)
inputs.py
#inputs.py
def system():
    pass
try:
    system.runPlace = 0 # robot
except:
    system.runPlace = 1 # laptop
class Attack3:
    def __init__(self, port):
	self.port = port
	self.joy  = wpi.Joystick(self.port)
	print "New Attack3 configured at port " + str(port)
    def getAxies(self, x_axis, y_axis):
	"""Returns a list in the format of [arg1, arg2]"""
	resultant = list()
	resultant.append(self.joy.GetRawAxis(x_axis))
	resultant.append(self.joy.GetRawAxis(y_axis))
	return resultant
    def getStickAxes(self):
	return self.getAxies(2,1)
    def getThrottle(self):
	return self.joy.GetRawAxis(3)
    def getButtons(self):
	r = [] #r is of type list
	for n in range(1,12):
	    r.append(self.joy.GetRawButton(n))
	#To the tune of ghostbusters:
	#When there's an annoying problem, that you need to solve?
	#whatcha gonna use?
	#A FOR LOOP!
	#when there's a lot of data
	#that you need to parse
	#whatcha gonna use?
	#A FOR LOOP!
	#I ain't afraid of no macs
	#XD
	return r
    def getTrigger(self):
	return self.getButtons()[0]
class Xbox():
      self.port = port
      self.a = 1
      self.b = 2
      self.x = 4
      self.y = 3
      self.lb = 6
      self.rb = 5
      self.back = 7
      self.start = 8
    def bufferIt(n):
	if abs(n) < 0.2:
	    n = 0
	return n
	resultant = list()
	resultant.append(bufferIt(self.joy.GetRawAxis(x_axis)))
	resultant.append(bufferIt(self.joy.GetRawAxis(y_axis)))
	return resultant
    def getAllAxes(self):
	r = list()
	for n in range(1,6):
	    r.append(bufferIt(self.joy.GetRawAxis(n)))
	return r
    def getButton(self, button):
	return self.joy.GetRawButton(button)
    def getButtonList(self):
	r = list()
	for n in range(1,9):
	    r.append(self.joy.getRawButton(n))
	return r
testing.py
#This file should emulate enough of wpilib to make it usable for testing
#TODO: use pygame to get joystick inputs from actual joysticks
def limit(n):
    if n > 1.0:
	return 1.0
    elif n < -1.0:
	return -1.0
    else:
	return n
class Victor:
        self.port = port
        print "Virtual Victor set up on port " + str(port)
        self.speed = float()
    def Set(self, speed):
        """***FOR TESTING PURPOSES ONLY***
       This "sets" the virtual Victor to any arbitrary speed"""
        speed = limit(speed)
        print "on port " + str(self.port) + " the speed is now " + str(speed)
        self.speed = speed
    def Get(self):
       This emulates the wpilib.Victor.Get function"""
        return self.speed
class Joystick:
        self.port = port
        print "New joystick set up at port "+str(port)
    def Get(self):
        return 0.5
def speedReport(list_obj):
    """Use this for the driver object"""
    for n in list_obj:
        n.Get()
def IsDisabled():
    return False
def IsAutonomous():
    return False
def IsOperatorControl():
    return True
def IsEnabled():
    return True
class dummyDog:
    def SetEnabled(self, var):
        pass
    def SetExpiration(self, var):
        pass
    def Feed(self):
        pass
def GetWatchdog():
    return dummyDog()
run debug_test.py
its a shell interface to my tests, you can throughly ignore show and var, it was a part of another project i attempted (and failed at)
driver does the cool stuff
have fun!
Speed Controllers Liu_yiang General Forum 11 07-02-2009 20:12
Speed controllers.... Denman Technical Discussion 14 07-10-2004 15:19
speed controllers archiver 2000 5 24-06-2002 00:19
Speed Controllers archiver 2000 1 23-06-2002 23:01
Speed Controllers... Tom Schindler Technical Discussion 4 13-12-2001 17:26
