Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 28-11-2010, 14:59
Joining the 900 Meme Team
FRC #0079
Re: Team 68's 40 days of chassis Design.
In addition to Nick's comment I also have to point out that with this system you will run into the same problem you did last year once you decided to lock your wheels. This frame will drive forward and back very well but will not turn.
Team 1527 Official Chassis Design!!!! cdennisxlx2 Technical Discussion 18 13-01-2008 15:55
Team 1527 Chassis/Electrical/Pneumatics Design... cdennisxlx2 Technical Discussion 9 09-01-2008 01:38
Team 68's Mentor Gadget470 General Forum 0 20-03-2003 22:45
Team 68's New Website Alexander McGee Website Design/Showcase 6 25-02-2003 21:09
Team 68's Robot Alexander McGee Robot Showcase 25 16-02-2003 14:32
