Go to Post ... as teammates we often get too into the craze of competition and forget that this wouldn't happen without so many dedicated people. - miketwalker [more]
Unread 29-11-2010, 08:06
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Creating iParts
Hey guys, I was wondering if any of you have had any luck with making your own iParts. I've messed around with the iSprocket and understand how they work, I'm just not sure how to create the dialogue box to input the desired dimensions.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 22-12-2010, 20:41
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Creating iParts
Alec,
This is Phil Dollan, I work with Autodesk and will be monitoring the CAD forum for the next couple of months.
Can you tell me what it is you are trying to use the iPart tools for? It looks like you are creating sprocket gears, if so, you are probably better using Design Accelerator to get the gear size you want.
Tell me a bit more about what you need and I will work with you to solve the problem.
Phil
Unread 23-12-2010, 16:14
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Re: Creating iParts
I was hoping to be able to create an iPart of half inch diameter aluminum spacers with 3/4 inch deep 1/4-20 threaded holes in each end.
creating tubing fluffy Inventor 3 07-03-2007 22:05
Creating a skeleton Setsanto 3D Animation and Competition 11 03-02-2007 14:55
creating environments stinger 3D Animation and Competition 5 26-02-2005 22:19
Creating Videos Raven_Writer IT / Communications 13 20-06-2004 23:48
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
