Go to Post They see us come into school looking like zombies, and they know that some people start smelling like chain lube and such...but for the most part, they don't realize that for a lot of us, there is a deep commitment to our team that we do a very large amount of work for that team. - JakeGallagher [more]
Unread 22-11-2010, 16:42
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
java code won't download
My Driver Station shows that the robot is connected through the wireless router, but when I try to download my Java code from NetBeans, it won't download. I click the RUN button in NetBeans and the output window shows it compiles and everything, but then it just says this:
Waiting to connect to OTA command server of 10.32.5.2:8001 for past 67s
It just says that repeatedly every second and I have to stop it. I tried to connect to the robot with the ethernet cable, but it wouldn't connect.
I am new to NetBeans, and I'm not sure exactly how to download it, I was just hitting the RUN button.
Please help!
Unread 22-11-2010, 17:53
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: java code won't download
First questions first: what OS are you running?
edit:
I noticed this error a lot more often on windows rather than linux, try an ubuntu install on a flashdrive and see if that fixes it
Unread 23-11-2010, 07:25
dbeckwith's Avatar
Lead Programmer
I'm running XP, but I think I might have found a solution though. I tried re-imaging the robot and it seems to work now, at least I can download the code. But now when I run it the infamous watchdog is hungry! The DS says Watchdog not fed whenever I try to do anything. I tried directly disabling the Watchdog in my Java code, but it still said it wasn't fed.
Unread 26-11-2010, 03:56
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Can you post the code that you are trying to download?
If it compiles and downloads correctly now, but you still get the watchdog error, it is most likely the code you are trying to run.
A Possible Cause could be that you are trying to download camera code, but the camera isn't pugged into the cRio via an ethernet crossover cable
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 26-11-2010, 19:25
1 * 4 != 14
add getWatchdog().kill();
Unread 29-11-2010, 18:33
dbeckwith's Avatar
Lead Programmer
I looked at the documentation on the Watchdog and it said that you have to feed it yourself, so I did that and everything works fine now.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Robot code won't load RevusHarkings C/C++ 3 18-02-2010 15:19
Java program won't run I am error Java 3 29-01-2010 13:51
User code won't download/run-possible causes? nathanww C/C++ 3 21-01-2009 11:00
Won't Download! diaperrash89 Programming 4 25-10-2007 23:02
2005 default code won't compile Robby Programming 22 04-02-2005 18:21
