Go to Post Engineering is NOT manufacturing. .... It is good to be able to fabricate things with your own hands, but thats not what engineers do. - KenWittlief [more]
Unread 30-11-2010, 20:06
biancs15's Avatar
biancs15 biancs15 is offline
Driver, Design and Manufacturing
AKA: Austin
FRC #0610 (Coyotes)
biancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to behold
pic: Coyobot 10
Unread 30-11-2010, 20:07
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: pic: Coyobot 10
Did they give you any trouble about the bumpers leaving the bumper zone?
Unread 30-11-2010, 20:41
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Re: pic: Coyobot 10
Whats the point of having this articulate? does it help get over the bump or onto the platform or something? I'm assuming its not just for show
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 30-11-2010, 20:51
Chris is me's Avatar
AKA: Pinecone
Re: pic: Coyobot 10
I believe the robot only entered this state on the bump or during the finale.
Unread 01-12-2010, 09:51
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Re: pic: Coyobot 10
Austin, this is actually Coyobot 11. You weren't around for Coyobot 10
Anyway, as some have suggested, the middle wheels are articulated primarily to assist driving over the bumps. They would be raised to facilitate this. But In this picture the middle wheels are lowered, which causes the robot to rear back. Obviously this violates bumper rules, etc. The plan was to climb up on the platform from the side via the bump. Climbing the platform was easy, turning on the bump to face the platform, not so much. Since the bump is such an awkward shape, the robot would often tip over when we tried to turn lengthwise on it. We only succeeded in making the turn a couple times during practise.
Unread 01-12-2010, 10:19
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Coyobot 10
Did you ever try approaching the bump at an angle less than 90deg so you did not have to turn much on top of the bump?
Unread 02-12-2010, 11:19
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: pic: Coyobot 10
How did you guys actuate your suspension? Are those pneumatics I see?
We had a very similar chassis set-up. It made for a much smoother bump experience. We used our arm to push down the center section. Initially we were using window motors and cables, but weight and efficiency issues required a different solution.
Unread 03-12-2010, 08:20
FRC #0610 (Coyotes)
Re: pic: Coyobot 10
Yes, we tried approaching the bump at all sorts of angles, and either the robot would tip over, or it would not be able to reach the top of the bump. The latter occurred when we approached the bump at a very slight angle, nearly parallel to it. The 45 degree slopes on the bump were very unforgiving.
The middle wheels were raised and lowered with pneumatics. Raising the wheels made bump crossing much smoother.
pic: The Coyobot 2010 biancs15 Extra Discussion 3 10-11-2010 10:25
610 - Coyobot X Duncan Macdonald Robot Showcase 9 15-03-2009 20:06
pic: Coyobot VIII - Picking up tubes in Waterloo Jonathan Norris Extra Discussion 10 26-03-2007 17:17
pic: 610 Coyobot VIII - Chassis View Jonathan Norris Robot Showcase 1 10-02-2007 17:18
pic: 610 - Coyobot VII Jonathan Norris Robot Showcase 7 23-02-2006 00:13
