Go to Post Consider that the 12V from your robot isn't any different from the 12V from your car's cigarette lighter. (Err... sorry... that's "power port" these days, thank goodness.) - dtengineering [more]
Go Back   Chief Delphi > Technical > Programming > Python
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 01-11-2010, 01:46
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
RobotPy 2010.beta2
I've just released a new version of RobotPy (Python for FRC), 2010.beta2. The RobotPy site has moved to FIRST Forge at the encouragement of Brad Miller at WPI; please update your bookmarks. The new location is:
http://firstforge.wpi.edu/sf/projects/robotpy
Major changes from 2010.beta1 release:
  • Separate packages for the Python core (interpreter and libraries) and the WPILib module. The Python core itself no longer depends on WPILib. This decoupling will allow for separate releases of WPILib for different years (e.g. for beta testing or maintaining old robot code).
  • Dynamic loading support for binary modules; many of the standard Python modules are now dynamically loaded (as is WPILib). This will make it easier to distribute additional modules as separate packages in the future as well (e.g. NumPy).
  • RobotBase, SimpleRobot, and IterativeRobot classes are now provided.
  • You can now derive Python classes from PIDSource, PIDOutput, SpeedController, and Joystick and pass the derived classes to WPILib (e.g. PIDController). This enables custom PID control in Python.
The wiki pages at FIRST Forge contain the most recent documentation. In the coming weeks I plan to work on improving the documentation further; currently it mostly describes the differences between the C++ WPILib and the Python version.
I expect to complete translation of 294's 2010 robot program to Python on Wednesday. When I post it for download I will also make an announcement here.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 01-11-2010, 23:02
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: RobotPy 2010.beta2
I have a complete robot program already coded up, all it needs are comments
Unread 19-11-2010, 19:00
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Good job robototes!
Unread 20-11-2010, 00:00
1 * 4 != 14
want a copy?
Unread 21-11-2010, 23:36
If you don't mind .
Unread 22-11-2010, 00:08
1 * 4 != 14
well crap.
I accidentally deleted it all, so it looks like i have to remake it
Unread 28-11-2010, 18:25
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Originally Posted by Robototes2412 View Post
well crap.
back this one up
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 28-11-2010, 23:20
1 * 4 != 14
i even made a computer testing interface for this one:
http://www.chiefdelphi.com/forums/sh...ad.php?t=87630
too lazy to copy the bbcode
Unread 29-11-2010, 22:20
1 * 4 != 14
i tried installing robotpy today, and it didn't work
Unread 30-11-2010, 00:07
WPILib Developer
Could you elaborate? Did you get any error messages in NetConsole? In order to help you get it working, I need more detail than simply "it didn't work".
Unread 30-11-2010, 00:43
1 * 4 != 14
we didn't have netconsole, all we got was watchdog/no code
Unread 30-11-2010, 02:41
WPILib Developer
You should definitely enable NetConsole to see what's going on. If it's simply "no code" that means the Python interpreter isn't starting. Watchdog likely means your Python code is raising an exception. NetConsole will show the details of any exceptions being raised.
Unread 30-11-2010, 21:43
1 * 4 != 14
How do I do that?
Unread 30-11-2010, 22:32
WPILib Developer
How do I do that?
See http://first.wpi.edu/FRC/frccupdates.html. There is a client download link and instructions for setup of netconsole under the C/C++ Team Update 4.0 section.
Future versions of the Imaging Tool will make it easier to enable the netconsole server portion. It's installed on the cRIO already, just not enabled by default in the C++ version.
Unread 30-11-2010, 22:34
1 * 4 != 14
oh, what port is this on?
RobotPy: Python for FRC Peter Johnson Python 28 17-10-2012 11:46
[FTC]: FTC 2010-2010 "A New Game" JohnFogarty FIRST Tech Challenge 2 21-08-2010 22:34
Connect a Million Minds 2010 Robotics Invitational, June 26, 2010 Columbus, Ohio Dr. Osemwengie Off-Season Events 29 03-07-2010 00:33
2010 accelerometer chsr C/C++ 1 22-01-2010 02:28
