Go to Post Only time will tell for sure, but it seems that the current software providers are hatching up a pretty good solution to the problem. - dlavery [more]
Unread 01-12-2010, 02:02
ygd ygd is offline
FRC #3341 (Manhattan Project)
ygd is an unknown quantity at this point
Installing Windriver C++
Our team used Java last year, but now we're switching to C++, but I'm having trouble installing Windriver Workbench.
I have the two-disc set that we got last year, so I popped in disc 1 and started installing. I unchecked the LabView and Java options and went on my merry way. Everything installed fine and it told me to switch in disc 2.
I did, and it began to install Workbench. A dialog from Workbench popped up, asking me for a license file. I searched the cd and found some preinst.lic that I fed it. It seemed to work fine, the install continued normally.
However, I could find no way to run the program, as the only exe's in C:\windriver were from the jre and vxworks tools.
Did I do something wrong, or is the executable hidden away somewhere?
Unread 01-12-2010, 03:08
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Installing Windriver C++
The license file is on the DVD. Here is an excerpt from my installation notes.
•During WindRiver installation, it will ask you for a licensing key. Choose "permanent activation" and point it to the licensing file located on the DVD at the following location:
<drive>:\Distributions\Wind River\FirstRobotics_2010_install.txt
Unread 01-12-2010, 23:32
ygd ygd is offline
Thanks, this worked. I'm not sure why I didn't get the message before.
Is this somewhere on FIRST's website? I must have missed it.
Unread 01-12-2010, 23:43
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
It's in the Control System Setup Manual, specifically page 8. Don't worry, I have trouble keeping track of all the manuals too
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 02-12-2010, 02:18
mikets's Avatar
Software Engineer
Yes, I have trouble remember where I read those too. That's why once I read it, I summarized the steps in my installation notes and post it on our team website so our programmers can just read that instead of scrambling with different docs. That excerpt was from my notes.
Installing on 64 bit. Team1710 Inventor 2 09-04-2009 19:45
Installing a Moto Roosevelt08 Technical Discussion 3 17-04-2008 13:32
installing easyC MarkH Programming 2 26-03-2006 07:33
Installing mplab Dominicano0519 Programming 2 07-03-2006 18:21
installing a tachometer greencactus3 Chit-Chat 14 07-11-2005 21:00
