Go to Post There is one unbreakable and unwritten law in FIRST, don't make it hard for your alliance partners to play. - Al Skierkiewicz [more]
Unread 01-12-2010, 13:43
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
[FTC]: Using rope on the robot
The other day we were finishing somethings on our robot, 3750, and we're using a winch to pull up our arm. For this we of course are using rope, we're currently using some 1/8" nylon rope but originally we had some 1/8" twine we were using and it kept braking. I work up at a boyscout camp and teach things like knots and rope making so I took the 1/8" twine and made it into 3/8" rope. Would this be legal to use? In my opinion yes because it is something we manufactured with allowed materials, but we wanted to be safe and use the nylon. So what do you guys think?
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 01-12-2010, 14:09
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: Using rope on the robot
I think it would be legal, I have wanted to make something that uses something like braided rope or string whatever we were allowed to use but, so far we haven't had the need for string on any competition bots.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 01-12-2010, 14:31
If you have 1/8" (3mm) cord around, why are you messing with twine? We've used the 3mm cord from REI on robots (when legal) for years and it has always been more than strong enough. Just wondering...
Unread 01-12-2010, 15:21
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Another interesting use of the allowed rope is to make a net.
So long as the individual purchased strand of rope material meets the materials specifications for diameter and length, there is no issue with using that material to make your desired mechanism (in this case, a thicker rope).
The caveat to this is that it will be up to YOU to PROVE to the inspector that the individual strand was purchased as such (i.e. you can't purchase a thick rope and say its individual strands meet the requirements...) as well as PROVE that the individual strands meet the size requirements. A very strict inspector may require you to unthread your rope if you go to inspections unprepared.
I'd also post this on the FTC Q&A just to be sure.
GitHub
Unread 02-12-2010, 12:45
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
If you're looking for strength, something you might want to look into is using the "plastic-coated wire rope with a bare wire diameter of 0.03125” or smaller" as they call it in the rules. We bought a short length and it was very strong, but surprisingly flexible; you should be able to use it in a wench. But if the rope works for your purposes, stick with it.
SAY-WATT.ORG
[FTC]: Using the Joysticks - Robot C Tutorial normalmutant FIRST Tech Challenge 2 28-10-2010 22:11
[FTC]: Tips page on using FTC Encoders with LabVIEW PhilBot FIRST Tech Challenge 7 27-01-2009 14:00
Using the IR remote to send radio commands to the robot Mikhail_Pham Control System 2 14-01-2008 00:14
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
Is rope allowable on my robot? Randy Ai Rules/Strategy 1 06-01-2003 17:17
