Go to Post I have never gone to a FIRST Robotics competition and not had fun. - mathking [more]
Unread 02-12-2010, 00:58
CIM Quiz 2
The following was inspired by a recent discussion I had about analyzing a vacuum ball magnet:
The power required to drive a certain vacuum impeller is given by the equation
watts = (rpm^2)/81500
The impeller is being driven by two motors: a CIM and an FP, each through a separate gearbox.
The motors are each being driven at 12 volts.
Find the theoretical gear ratios of the two gearboxes which produce the fastest impeller speed.
[edit 11:56am] Note: for purposes of this analysis, ignore gearbox losses. [/edit]
[edit 4:54pm] Note: For this hypothetical problem, ignore the 40amp breaker and allow each motor to draw whatever current it needs (with 12V applied) in order to maximize the impeller speed. Pretend the impeller is only operated momentarily. [/edit]
Unread 02-12-2010, 03:06
rahilm's Avatar
rahilm rahilm is online now
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: CIM Quiz 2
Spoiler for My Attempt:
CIM : ~1:2 (1:1.97)
FP : ~5:1 (1:0.21)
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 02-12-2010, 11:15
Re: CIM Quiz 2
CIM : ~1:2 (1:1.97)
FP : ~5:1 (1:0.21)
At those gear ratios, the FP is not helping the CIM. It is actually acting as a generator, putting additional load on the CIM.
Post or PM your calculations if you want to discuss.
Unread 02-12-2010, 11:34
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: CIM Quiz 2
Is the "Power" required to drive the impeller electrical watts or mechanical watts? Also, what are the units on the 81500 constant? I only ask because my first pass at this has no bounds.
GitHub
Unread 02-12-2010, 11:51
Re: CIM Quiz 2
The impeller is driven mechanically by the two motors (through their respective gearboxes). The formula watts = (rpm^2)/81500 gives the mechanical power input to the impeller required to spin it at the specified rpm.
The units on the 81500 would have to be (rpm^2)/watt.
For example, to spin the impeller at 5000 rpm would require (5000^2)/81500 = 307 watts.
Hint: this problem has a closed-form solution, although you could just set up the equations and iterate rather than solve algebraically.
Unread 02-12-2010, 15:38
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: CIM Quiz 2
Ok. My first question is where did you get the specs for your impeller (is that provided by the manufacturer?).
Anyway: (apologies in advance - this is for 10.5 volts as that is all I had on my scratch pad from when I worked a similar problem before)
Cim @ 35 amps: .70 Nm torque, 230 W, 395 rad/s = 3770 rpm
Fish @ 35 amps: .260 Nm torque, 180 W, 686 rad/s = 6550 rpm
Total power, 230 W + 180 W = 410 W (assuming zero loss - real life I'd throw a 20% in here).
410 W= rpm^2 / 81500, rpm = 5780 rpm
3770 (cim) / 5780 = .65:1 or 1:1.53 for the cim.
6550 (fish) / 5780 = 1.13:1 for the fish.
Your request didn't specify the maximum amperage, so I assumed 35 to be safe for our 40 amp breakers. If taken at 12 volts these will be slight different. This is based on the free speed of the motors at 10.5 volts, but truthfully it shouldn't be /that/ far off from 12 volts.
Unread 02-12-2010, 16:34
Jared Russell's Avatar
Taking a year (mostly) off
Re: CIM Quiz 2
I believe you are making the mistake of assuming the motors are providing their maximal mechanical power while spinning at their free speed.
Unread 02-12-2010, 16:45
rahilm's Avatar
AKA: Rahil Mehta
Re: CIM Quiz 2
Definitely misread the question.
Spoiler for Revised attempt:
CIM - ~1:2.5 (1:2.45)
FP - ~1.2:1 (1.15:1)
Unread 02-12-2010, 16:53
Re: CIM Quiz 2
Sorry for not being clearer: For this hypothetical problem, ignore the 40amp breaker and allow each motor to draw whatever current it needs (with 12V applied) in order to maximize the impeller speed. Pretend the impeller is only operated momentarily.
Tom: could you please PM me or post your 10.5 CIM and FP motor curves. Thx.
Unread 02-12-2010, 16:55
Re: CIM Quiz 2
Spoiler for Wherein the EE turned SE tries to be an ME:
CIM puts out 337W @ 2655 RPM
FP puts out 184W @ 7500 RPM
674W Total is ~7411 RPM fan speed.
CIM gearing is ~2.79
FP gearing is ~.988
Unread 02-12-2010, 17:00
AdamHeard's Avatar
Lead Mentor
Re: CIM Quiz 2
A hint to all.
You have two unknowns, power and speed.
Two equations relating them to each other (one from the motor, one from the impeller).
Unread 02-12-2010, 17:07
Re: CIM Quiz 2
What he did, I believe, is to pull the following data:
... from some 10.5 Volt motor curves that he has.
He then reasoned as follows:
- if 35 amps are supplied to each motor, they will produce the output power indicated above at the rpm's specified above (if his 10.5 motor curve data is valid, this is valid reasoning)
- the sum of the output power from each motor is then used to calculate how fast the impeller will spin, given that power
- that impeller speed is then used to calculate what the gear ratio must be for each motor in order for each motor to be spinning at its respective specified rpm when the impeller is spinning at the speed just calculated.
It's an interesting solution, but it's not the solution to the problem I had in mind because it requires that the current to each motor be controlled at 35 amps. The problem I had in mind did not involve controlling the current. As stated, each motor is being driven at a constant voltage (12V), not a constant current.
Unread 02-12-2010, 17:16
Re: CIM Quiz 2
A hint to all.
and two gear ratios makes four.
Unread 02-12-2010, 17:21
Re: CIM Quiz 2
Pretty close. Show your calculations so we can discuss.
Unread 02-12-2010, 17:29
Re: CIM Quiz 2
FP gearing is ~.988
Well done !
(but where did you get your FP motor data from? It differs slightly from what I have)
CIM quiz Ether Motors 20 21-11-2010 19:13
Safety Quiz? morg102 Games/Trivia 1 20-01-2009 13:23
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Gundam Quiz GAT-X105 STRIKE Games/Trivia 3 09-02-2005 17:11
Team Quiz MrsT General Forum 7 02-03-2002 18:54
