Go to Post The real world does not go together like an Erector set. FIRST robots should not either. - dlavery [more]
Unread 02-12-2010, 17:52
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: First Robotics Books
There are two editions. One from the 2006 and one from the 2007 season. They are an amazing resource on the thought process that goes into the design of the robots.
Teams that won technical awards that season submitted a presentation and 30 were selected for each year.
They are a great read and will give you a lot of insight as to how teams work.
Unread 02-12-2010, 18:22
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
They're a little bit of both, really. The text of the books is, in many cases (and perhaps only in my opinion), sparse on useful technical details. If you know what you're looking at, though, and what you're looking for, the pictures and drawings are a helpful resource.
--Madison--
...down at the Ozdust!
I'd get both. They are coffee-table books, but they give a lot of insight into the processes behind some of the top teams in FIRST. 1114, 111, 357, 330, 190, and 33 are just some of the teams that I remember being in one or both. 357 happens to have a patent on an item they developed in FIRST; some of 33's software wound up in at least one Chrysler model some years ago, IIRC.
Unread 04-12-2010, 20:36
I was wondering if there's someone from Team 75 who could explain the attached excerpt from page 78 of the 2008 edition. It doesn't sound right.
Name:	2008 Page 78.jpg
Unread 04-12-2010, 20:42
The Big CIMs were before you were involved, I think--I remember them in '06 and maybe '07. Many teams noticed that they didn't have the same or better performance as the CIMs that we use these days, which we also had then. They were also about the third-heaviest item in the KOP, weighing in right behind the batteries and the compressor. Hence, a lot of teams didn't use them.
The teams that did tended to use them outside of the drivetrain.
Unread 04-12-2010, 20:55
OK, I can understand not using the large CIMs because of their larger size and weight, but that was not the reason given.
According to the motor curves I have, the large CIMs seem to be more efficient (power out divided by power in) than the small CIMs. Perhaps I have the wrong curves? Or perhaps it wasn't a question of efficiency but rather the higher power output of the small CIMs ?
Is there someone from Team 75 that remembers this analysis and could fill in some details?
Unread 04-12-2010, 21:15
IIRC, it was the smaller CIMs had a higher power output. Big CIMS appeared in places like 330's shooter and in various lifts; not many were in drivtrains.
Unread 04-12-2010, 23:22
Chris is me's Avatar
AKA: Pinecone
Not from 75, but I think they meant that a big/small CIM combo geared for the same free speed as a 2x small CIM combo would draw more current under load.
Unread 04-12-2010, 23:35
Thanks Chris. I'm trying to parse what you wrote. Are you saying that the comparison was between
a) 2 small CIMs driving a gearbox
and
b) one small CIM plus one large CIM driving one gearbox (so that the small and large CIM are being driven at the same speed ?
I wouldn't have guessed that from what was written.
If what you say is true, sure that's not optimum. The large CIM's NLS is half that of the small CIM. There's no way to operate such a design efficiently.
Unread 05-12-2010, 03:14
AKA: Pinecone
I believe a larger pinion was put on the large CIM to compensate for this.
Unread 05-12-2010, 09:20
If the large and small CIMs were geared so that each one was running at the same percent of its own no-load speed, then the large+small combination should be more power-efficient than the small+small combination, according to the motor curves I have for the large and small CIMs.
If there's a piece of the puzzle that's missing perhaps someone from Team 75 who was involved in this analysis would clarify.
Unread 05-12-2010, 10:20
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
AndyMark produced a special version of their super-shifters to allow the use of one big cim and one small.
Unread 05-12-2010, 16:15
You don't happen to have the model number for that somewhere in your notes do you? I couldn't find it on AndyMark. Thought maybe if I Googled it I could find some hits.
Unread 05-12-2010, 16:56
IndySam's Avatar
AM Gen 2 came with different side plates for the large cim.
http://www.andymark.com/ProductDetai...ctCode=am-0076
check out the pdf for a good view.
http://d1pytrrjwm20z9.cloudfront.net/amshifter2-asm.pdf
FIRST Research Paper - Need Books/Mags Willnet General Forum 9 02-12-2010 09:52
Books for robotics related engineering in high school rsisk Robotics Education and Curriculum 1 09-05-2010 18:02
How many FIRST books are in a case? (logoloc ?) Elgin Clock General Forum 4 19-07-2007 14:45
Best Robotics Books Myrddin157 Math and Science 5 30-12-2004 11:11
Books on electronics relating to robotics patrickrd Technical Discussion 1 15-05-2004 21:28
