Go to Post Who knew there were this many FRC teams that are teams! Very impressive, I might add. - [more]
Unread 02-12-2010, 18:52
Re: Mecanum - use of gyro
This "automatic delta time calculation" ... where in the documentation is that explained? The help file says only this:
dt (s) specifies the interval, in seconds, at which this VI is called. If dt (s) is less than or equal to zero, this VI uses an internal timer with a one millisecond resolution. The default is –1.
... nothing in there about automatic delta time calculation.
The second sentence of the documentation you quoted states that it uses a timer to calculate delta t, which sounds like "automatic delta time calculation" to me.
Because the VI's default for dt is -1, the default behavior is for it to calculate its own dt internally based on the timer. When you wire something real up to it, that will disable the timer and use that value instead.
Why you WANT to use a Gyro this year JesseK Electrical 10 19-01-2010 15:49
[FTC]: Anyone know how to use the Gyro? ttldomination FIRST Tech Challenge 0 31-01-2009 21:19
Ever use a helicopter heading hold gyro before? seanwitte Electrical 7 16-01-2008 12:59
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Gyro Chip: How To Use archiver 1999 3 23-06-2002 21:57
