Go to Post "I don't have a cockroach in my presentation.... " I will remember this line forever. Thank you Autodesk. - Zyik [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 02-12-2010, 17:37
RcDawson RcDawson is offline
FRC #2972
RcDawson has a spectacular aura aboutRcDawson has a spectacular aura about
Fan Power
Hi I was wondering how I would power a fan to keep electrical parts cool.
They are currently connected to the digital side car with PMW cables.
We simply need them to run whenever the cRIO is on.
Any Ideas?
Greg.
Team 2972
Unread 02-12-2010, 17:55
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Fan Power
Any Ideas?
Greg.
Team 2972
What size fan are we talking about?
Small muffin fans? Large props?
___________________
- Tennyson, Ulysses
Unread 02-12-2010, 18:28
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Fan Power
Why power the electrical components like the Crio? This is an honest question, as I am confused as to any possible reason. I would imagine components like the Jaguars/Victors or distribution board may need the cooling due to huge currents, but for control components?
Unread 02-12-2010, 19:16
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: Fan Power
Greg,
We use a spike to control the fans. We place the KOP fans over the drive train motors to increase air flow over the motor casings. Cool air over the motors really helps out if you run hot especially in practice mode. Anything you can do to cool the motors down will increase your efficiency.
Roy
Unread 02-12-2010, 21:02
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Fan Power
If you want to go really advanced, you could set up a thermometer to measure the temperatures, then hook the fans up to a Victor/Jaguar to control how fast they spin, thus regulating your temperature...
Unread 02-12-2010, 21:07
WPI Freshman
AKA: Alex
Re: Fan Power
I do believe the fans do not operate with a reverse voltage, as do the brushed DC motors.
Unread 02-12-2010, 21:16
Re: Fan Power
The simplest solution is to run the fans from a single circuit breaker on the power distro board. They will turn on when the robot is turned on. The electrical rules require a #18 wire be connected to the PD but you may buss several fans together and then tie them to the #18. Insulation is required on the exposed wiring, the use of heatshrink tubing is highly recommended.
Using a Spike to control fans under software control is an acceptable option as well.
Will a 1/3 horse power sump pump motor burn up at half power? Weird Al/ Tony Motors 46 09-04-2010 21:11
WHAT'S A FAN!? kngscrpn24 Technical Discussion 16 29-01-2010 09:25
Power distribution board does not give power to access point bitsoglass NI LabVIEW 3 17-02-2009 12:07
light up fan Dremel Drew Electrical 9 08-02-2007 23:28
Fan Club! TheManTheMyth Chit-Chat 3 29-10-2006 07:30
