Go to Post But altering register values via bitwise operations in nested ternary commands is so much fun! - artdutra04 [more]
Unread 02-10-2002, 23:19
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
RoboEmu 1.03
Well, this should be the last of the 20-hour apart releases, but it all depends on how many errors you guys manage to find.
Anyway, it now works with all the code I have, both real robot code and test programs I've created. I fixed the offset error gwross pointed out, as well as a few other bugs. See the changelog for full details.
In any event, it's available, as always, at:
http://FIRSTprograms.tripod.com/Programs.htm
Unread 03-10-2002, 00:57
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
One thing RoboEmu needs is some sort of project file which would store the program file names. (Actually, why should we need to specify all the file names at all? It's all right there in the main program file.) It would also be nice to be able to specify alternate labels for all the inputs and outputs. I.e. instead of PWM 1, it would be nice to see Left Wheel; and instead of Switch 3, Right Goal Lifter Limit Switch would be much clearer. (All this would of course be stored in the project file too.)
Unread 03-10-2002, 11:48
Good idea. For now, I have a lot of school work to do (national merit application do tomorrow!), but I'll work on it when I get the chance. The idea of changing names of things is definately on my list of priorities now that you mentioned it. As is project files.
Does the current version work correctly for your program, gwross? I know it runs without errors, but is the output correct?
Unread 03-10-2002, 13:34
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
I'm not sure. I didn't take the time to figure out which PWM controls which wheel, and which joystick is which, etc.
Unread 13-10-2002, 22:22
Okay, I just finished the updates and uploaded the new version. I fixed the MFC42d.dll error while I was at it, too. Let me know what you think!
Unread 14-10-2002, 11:00
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Thumbs up RoboTools 1.04
Rob,
Thanks for the MFC42d.dll fixes I can now run the program. Now for my bug list:
1. When I type in a number in the Sensors field and press Enter, the Inputs window closes.
2. I get frequent Application Errors when opening or changing projects: (“The instruction at “0x7800d307” referenced memory at “0x00411314”. The memory could not be written”)
3. When I try to run a multi slot program, all the output stay Paused if I have “RUN 1” in the program. (I will e-mail my code to you)
Wish List Item:
1. Add a “recently used project list” to the File menu.
2. Show Debug outputs on your screen.
[b]
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 14-10-2002, 12:41
ateene ateene is offline
#0159 (Alpine Robotics)
ateene will become famous soon enough
Rob,
This is a great program.
I'm having problems opening files. I can open and run the basic DefaultProgram.bsx, which I downloaded from Innovation First. But when I try opening your Cogsquad code I get a program error. I get the same error when I try opening one of our programs. I'm running this on Windows 2K.
What are all the slot fields for in the Open Files Dialog box? I'm entering the program file in slot 0 field.
Thanks,
Andres Teene
Andres
Team 159 - Alpine Robotics
2002 - Seattle Regional Chairman's Award
2002 - Seattle Regional Kleiner Perkins Entrepreneurship Award
2002 - Newton Division #4 Seed
2002 - Newton Division Quarterfinalist
Unread 14-10-2002, 16:27
ttedrow's Avatar
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Slots
Andres,
The basic stamp processors has up to 8 slots for programs. All the slots share the same RAM and Scratch Pad RAM space. So be careful in using multiple slots in your programming.
I am also having some problems loading programs. I can't get any programs to load us WinXP and I get occational Application Errors us WinNT.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
Yes, Chute Door!!!
Unread 14-10-2002, 17:07
Hmm... I don't have any winNT-based computers in my house, so I haven't tested it on those platforms.
As for the other errors, I'm working on it. Check back later tonight for (hopefully) 1.05, which should fix all the problems.
Unread 14-10-2002, 17:21
Well, this really blows. For some reason, "Debug" builds work just fine, but "Release" builds die miserably. Unfortunately, I can't release a "Debug" build because it links against MFC42d.dll instead of MFC42.dll. The problem comes from the fact that MS doesn't allow the redistribution of the "d" version. At least I have something to do for the rest of the night.
RoboEmu 1.11beta1 rbayer Programming 42 03-04-2003 13:53
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
Making RoboEmu 1.09 work rbayer Programming 2 14-01-2003 00:49
RoboEmu 1.08 released rbayer Programming 9 26-12-2002 22:31
RoboEmu 1.06 (works with XP and 2k) rbayer Programming 4 20-10-2002 21:47
