Go to Post It keeps your minibot from being destroyed by Dean's chainsaw, which is a big competitive advantage in future matches. - Joe Ross [more]
Unread 04-12-2010, 14:46
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Google's Interview Questions For Software Engineers:
http://blog.seattleinterviewcoach.co...tware_engineer
Those that stood out to me were:
1.)What is the difference between a mutex and a semaphore? Which one would you use to protect access to an increment operation?
2.)What is multithreaded programming? What is a deadlock?
3.)In Java, what is the difference between static, final, and const. (if you don't know Java they will ask something similar for C or C++).
Now there are some very hard questions for highschoolers but the above ones don't seem as complex.
Now I can only answer #2. A dead lock is when the 2 processes are dependent of each other so they are both waiting for each other to pass something but they won't pass it unless they get something... Pretty much that whole you step to the side and the guy in front of you do the same and you do that forever
Reading that list, even the lower programmers for Google are pretty hardcore. That just shows how long I have to go
FIRST Selected for Google's Project 10^100 Pat Fairbank General Forum 10 04-10-2010 23:17
Need to Interview a Software Engineer.... programmr Chit-Chat 4 12-10-2009 13:36
Questions for Mechanical Engineers Jacob Paikoff Career 8 02-09-2009 13:10
Chairman's Interview Questions Corey Balint Chairman's Award 1 24-03-2008 22:09
Interview room & judging panel (rookie questions) dhitchco Chairman's Award 52 20-03-2005 01:50
