Go to Post A robot with hands would be cool! - Koko Ed [more]
Unread 04-12-2010, 17:26
Re: Breakaway question: getting on platform with meccanum?
Originally Posted by RoboMaster View Post
Now that I think about it, that might not really work. The catching rollers would have to stick out farther than the others to be the only ones that catch on the lip of the platform. However, it still might work since all the rollers are angled.
Which is exactly why it probably wouldn't work. If you were at an angle (and mecanums can move at 45* if they're programmed right), you might be able to get up if the rollers could lock relative to the wheel.
Angle of the rollers won't help if you're going straight sideways. Let's say that they did catch, though, just for the sake of argument. If the platform had a lip (it doesn't), up-going rollers could catch as well as down-going rollers. Bam, you're going nowhere at best, and going onto your top at worst (one wheel locks up solidly). Same argument applies for a flat surface that gets hit broadside by a mecanum--down+up=nothing doing.
The fact that they're rollers doesn't help you much, either; they roll. CG is off the platform, so they'll want to roll off of said platform unless they're locked--at which point you get into either lousy strafing ability or lots of mechanical complexity to lock when you want to climb.
A late question about Breakaway matches sithmonkey13 General Forum 4 03-12-2010 22:48
pic: Breakaway Field Mockup (now with a simulator!) 1986titans Extra Discussion 48 18-04-2010 20:26
Question...(Cart & Platform) drunkengamer117 OCCRA Q&A 1 16-09-2006 10:30
Question...(Cart & Platform) drunkengamer117 Rules/Strategy 0 13-09-2006 15:13
Robot with segway drive platform Andrew Rudolph Dean Kamen's Inventions 1 14-11-2003 23:54
