Go to Post If poker is a sport, robotics is definitely a sport. - EricH [more]
Go Back   Chief Delphi > Technical > IT / Communications > Computer Graphics
Unread 05-12-2010, 09:15
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: FIRST logo with out the white background
That would be found at the FIRST site
http://usfirst.org/roboticsprograms/....aspx?id=17122
My assumption would be that the GIF versions have transparent backgrounds, check and see.
Kettering Motorsports
Unread 05-12-2010, 10:16
Dr.strangelove Dr.strangelove is offline
FGD-135
AKA: Jacob
no team (---)
Team Role: Animator
Dr.strangelove is an unknown quantity at this point
Send a message via AIM to Dr.strangelove
Thank you for the help.
Unread 05-12-2010, 15:15
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Please also be sure to read the guidelines involving the use of the FIRST logo and the "Branding & Design standards" before using the logo anywhere!
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 05-12-2010, 19:25
TACG's Avatar
TACG TACG is offline
AKA: Anna Hazel Moore
FRC #3502 (Octoπrates)
TACG has a spectacular aura aboutTACG has a spectacular aura about
This.
But even if you can't find it there, it shouldn't be hard to just select the white part by hitting "select by color" in photoshop or Gimp and getting rid of it.
Our brains are not quite full
So stuffed with half-thought thoughts
Math problems still to solve
Unread 05-12-2010, 20:28
FGD-135
AKA: Jacob
no team (---)
Team Role: Animator
thank you for the URL to was a big help
Unread 09-01-2011, 22:39
Samuel Marks Samuel Marks is offline
FRC #3132
Samuel Marks is an unknown quantity at this point
I'm a little late to this ball-game, however thought I'd add this tip on how you can turn the background to alpha with GIMP.
Here is the documentation page: http://docs.gimp.org/en/plug-in-colortoalpha.html
Unread 24-01-2011, 13:11
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
If you have Photoshop, I would recommend using the .eps format. You can open it in PS, at any resolution because it is a vector based eps. The background is by default transparent. Saving as a png will give you a 8 bit alpha channel, (pixels can be partially transparent) as opposed to a gif with 1 bit transparency. The option of selecting a color to be transparent will not anti-alias to the color behind it (on your webpage) unless you had that color to begin with. 32bit png file will look good because the partially transparent pixels at the edge of the graphic blend into whatever color is behind it. make sense?
I would imagine GIMP can do the same, but I rarely use GIMP.
pic: Fun with the FIRST Logo Ian Curtis Extra Discussion 4 23-07-2010 17:40
FIRST Logo with Transparent Background? tdlrali Computer Graphics 6 18-08-2008 23:45
Out with the match list printouts, in with... Pat Fairbank General Forum 19 07-02-2005 20:15
major issues with the background checks Andrew Dahl General Forum 2 12-12-2003 20:49
The background seen round the FIRST world archiver 2001 2 23-06-2002 22:14
