Go to Post We want to be a positive force in our community, and maybe to encourage our country’s best and brightest to go to work for the ones who’ve put themselves in harm’s way. - Jack Jones [more]
Unread 05-12-2010, 17:37
Re: How do you build telescopes/forklifts?
Leav,
We have used manufactured slides in the past. I think our Triple Play robot used slides from McMaster. In other years we have manufactured our own using sheet aluminum bent to nest and telescope. Almost exclusively we use Spectra cable I think from McMaster. It is pretty amazing stuff as far as strength vs. size. We manufacture cable reels using delrin and string them through each section of lift from top to bottom of each section. As the reel pulls on the cable it becomes shorter raising the sections. If you design for two sides to lift, I recommend using a dual reel so that the cables are drawn at the same speed and distance. We have generally used FP motors or window motors in the lifts in the past.
How many of you build your own field? Jessica Boucher General Forum 43 07-03-2006 21:15
[ECDU]: How involved in the build are you? Steve Howland FIRST-related Organizations 7 08-03-2005 12:12
How long did it take for you to build your drivetrain? NoodleKnight Technical Discussion 18 29-12-2004 16:13
How many of you build computers? Alphawolf829 Chit-Chat 8 15-01-2003 16:19
how do you build a robot? archiver 2001 1 24-06-2002 01:59
