Go to Post keep making a difference out there everyone...slowly but surely everyone will catch onto FIRST and then the world will be a better place :) - tiffany34990 [more]
Unread 05-12-2010, 20:30
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
2011 C++ Beta Testers?
Greetings!
Can any of the 2011 control system beta testers comment on the selection of sensors? I.e., has the control of the Hi-Technic/Lego I2C sensors been improved? I'm just curious about what sensors are supported this year.
On a related note, has the CAN Jaguar support been integrated into the WPILib? Does this include working with the shaft encoder on the Jaguar?
TIA,
Mike
Unread 05-12-2010, 21:10
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Re: 2011 C++ Beta Testers?
Honestly, 166 hasn't seen ANY difference in WPIlib. Sensors that we've tried are exactly the same as last year. We haven't tried Hi-Technic etc sensors, though.
CAN still isn't built in...
GSR Dean's List Finalist 2011
Unread 06-12-2010, 05:30
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The I2C hardware implementation now supports a wider selection of sensors due to the addition of a compatibility mode which detects clock skewing more aggressively (at the expense of performance).
CAN support is in the process of being integrated. The next beta update will include it. I'm not sure when Brad is planning to release it. Last I heard it was going to be released 2 weeks ago. The CAN Jaguar support is not yet upgraded to support the new jag FW, but last years library is in the WPILib trunk awaiting release.
-Joe
Unread 06-12-2010, 05:31
What improvements are you hoping for? We have had no feedback on the implementation, and as such have not done anything to change it.
-Joe
Unread 06-12-2010, 13:09
Software Mentor
AKA: Mike Anderson
-Joe
HI Joe,
I'm just trying to see what of the full range of Hi-Technic sensors will be supported. We had some problems with the stability of the 2010 Gyro/Compass and we're looking to see how much of the FTC kit can be used this year.
Some of the newer Hi-Technic sensors like the magnetometer and the EOPD look really interesting if we can make them work with WPILib with a minimum of hassle. We also had a few problems with the I2C support in last year's WPILib, so we were looking to see if anything had changed.
TIA,
Mike
Unread 06-12-2010, 19:36
The Compass is the only one in the C++ library at the moment. I think there is a LabVIEW example for the Accelerometer that could be ported to C++. No Gyro, though. Don't have one.
All of the HiTechnic sensors should be pretty trivial to support... I just don't have any of them and no-one else has contributed drivers or hardware so far. Perhaps I'll dig around and try to find some of these devices in various NXT stashes that others have.
-Joe
Unread 08-12-2010, 16:01
ptan ptan is offline
Paul C. Tan., P.Eng.
AKA: Paul Tan
no team (Bolt Action)
ptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to behold
-Joe
If you could support the HiTechnic (FTC) Gyro, that would be great! I have a few of them lying around that my FRC team could use.
Coach - FTC Team 27 (now retired)
Coach - VRC Team 2027 (now retired)
Past Mentor - FRC Teams 188, 610, 1009, 2634
Unread 13-12-2010, 21:55
Not possible, I'm afraid... the Gyro from HiTechnic is an analog sensor. The digital sidecar (as it's name suggests) is for digital only... You could use the HiTechnic Gyro if you cut open an NXT sensor cable and wire it up to the Analog Breakout.
I'd be surprised if you got better performance from it than you do from the kit gyro, but I haven't tested it.
-Joe
ZomB Dashboard 0.6: Beta testers wanted byteit101 Programming 17 29-07-2010 15:52
Looking for Beta testers at NJ Regional knittinggears General Forum 4 02-03-2010 18:56
Beta testers needed scitobor 617 Website Design/Showcase 9 30-05-2005 12:48
LINUX Users: Requesting beta testers jdong Programming 35 20-03-2005 13:28
Beta Testers blueWarrior FIRST-related Organizations 4 18-06-2003 19:48
