Go to Post I've always suspected that one could find glimpses of wisdom, setting priorities, and responsibility - and ways to balance them, in the contents of a coffee cup. - JaneYoung [more]
Unread 06-12-2010, 22:01
mobilegamer999 mobilegamer999 is offline
FRC #3357 (Comets)
mobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the rough
Talking iPhone Driver Station, No Computer Needed
Title pretty much says it all.
I have created a iPhone/iPod touch (sorry iPad users) application, that allows for full, 100% control of the robot without the need for the driver station, becasue the application IS the driver station.
The app features the ability to
  • Enable/Disable the robot
  • Teleop/Autonomous Control
  • Read battery voltage and robot state
  • Full digital and analog I/O
  • 10 joystick buttons
  • 2 virtual joysticks
  • accelerometer control
Future Abilities will include
  • Camera View
  • Robot debug messages
  • Anything suggested that is "reasonable"
This app will have a few final improvements to be made (icons, splash screen, etc) but should be submitted to apple shortly. Updates will be posted on the state of the applications submission progress
Also attached are a few images of what the UI looks like so far. As always on CD, any and every comment/suggestion is more than welcome.
Edit:
This application also requires no flashing/specialized reprogramming on the robot to work, joysticks are initialized and read in as normal.
Name:	Photo Dec 06, 3 40 10 PM.jpg
ID:	9470  Click image for larger version
Name:	Photo Dec 06, 3 40 37 PM.jpg
ID:	9471  Click image for larger version
Name:	Photo Dec 06, 3 40 47 PM.jpg
ID:	9472  Click image for larger version
Name:	Photo Dec 06, 3 41 02 PM.jpg
Unread 06-12-2010, 22:22
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: iPhone Driver Station, No Computer Needed
Can I ask how you got it to communicate with the robot without the driver station.
I always thought the communication was proprietary.
Unread 06-12-2010, 22:23
MrHance's Avatar
MrHance MrHance is offline
Long Distance Mentor
FRC #0647 (Cyber Wolf Corp)
MrHance has a spectacular aura aboutMrHance has a spectacular aura aboutMrHance has a spectacular aura about
Thumbs up Re: iPhone Driver Station, No Computer Needed
This is great news!
But what about those that do not use the I-phone/I-touch?
Is the program able to be transfers to other systems?
Are you working on an I-Pad version?
Can this be uses for a touch screen laptop computer?
These would be excellent options for various other input devices.
Again, Great work.
Unread 06-12-2010, 22:27
Ethan E Ethan E is offline
FRC #1683
Ethan E is an unknown quantity at this point
I knew that creating a custom dashboard was (relatively) simple, but was under the impression that the driver station (I/O, joysticks, enable/disable) was locked down by FIRST. Did they publish an API, or did you reverse engineer it, or what? (Sorry if the answer is obvious, I don't frequent CD too much)
Unread 06-12-2010, 22:31
FRC #3357 (Comets)
@davidthefat
#EDIT
I used a mix of packet analyzer (wireshark - a program to analyze the packets being sent to/from the drivers station) and packet definitions found in WPIlib to determine how the robot and driver station communicated so I could make an iPhone application that would communicate in that manner.
@MrHance
It could be written for other systems without a tremendous amount of work, more details about what system you would like it made for would be helpful. Also, i would like to make an iPad version of this to test with, but the lack of an iPad to test with is kinda an obstacle (however i might be able to borrow one from someone)
Unread 06-12-2010, 22:37
BrendanRadabaug's Avatar
BrendanRadabaug BrendanRadabaug is offline
FRC #1902 (Exploding Bacon)
BrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to behold
really want it, cant wait to try it out and possibly break our robot with it.
Bacon
Unread 06-12-2010, 23:07
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Looks sweet. I'd love to try this out. I'll be waiting. Is this app going to be free?
Unread 06-12-2010, 23:18
FRC #3357 (Comets)
@kgzak
the finesse and approval process will probably take about 3 weeks or so, and im planning on either .99 or 1.99, but im leaning more towards 99 cents.
Unread 06-12-2010, 23:50
kgzak's Avatar
AKA: Kris
Are you using it as a fund raiser for your team?
Unread 07-12-2010, 00:16
FRC #3357 (Comets)
not really, its more of a "help me through college" deal, but if the app turned significant profit, a good portion WOULD go to my team.
Unread 07-12-2010, 11:37
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
This sounds really interesting.
So it should work with any current robot, no matter what the programming language is? Will the cRIO properly recognize the "getY()" function from the Iphone?
Regardless, I can't wait for it to come out and test it.
Unread 07-12-2010, 11:57
zwz8495's Avatar
zwz8495 zwz8495 is offline
Team 1677 Mentor
AKA: Zach W
FRC #1677 (Quantum Ninjas)
zwz8495 is an unknown quantity at this point
Send a message via AIM to zwz8495
That is really amazing. I cant wait to try it out.
Unread 07-12-2010, 12:01
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
Nice idea! i would love to see a port for android phones sometime
2010 CO Regional: Finalist
2007 CO Regional: Semi-Finalist
Unread 07-12-2010, 12:03
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Ditto!
Unread 07-12-2010, 12:58
FRC #3357 (Comets)
Me and my friend are hoping to make an android version, it will take me a little time to get used to the android sdk versus iPhone sdk, but I will keep everybody posted on android status
Driver Station? qpang FRC Control System 2 27-01-2010 16:59
Personal Computer Problem With FRC Driver Station Pewter_Newb General Forum 2 19-01-2010 23:26
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
