Go to Post I think its great that some teams are 100% student built; but I would also hope that 100% of their students are mentor advised. - =Martin=Taylor= [more]
Unread 19-11-2010, 14:16
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
Re: [FTC]: Autonomous Ideas?
That's a pretty good plan. Remember that the scored batons will be counted again at the end of teleop, so that makes 30 points. That would be pretty good right there, and then if you go to the other side, dispense and store the doubler, then dispense all the rest of the batons... Wow. That's 70, with the potential for another 15 if the doubler is scored. Yeah, that's better than most of the higher teleop scores at the scrimmages so far.
SAY-WATT.ORG
Unread 26-11-2010, 21:43
alphadog0309's Avatar
alphadog0309 alphadog0309 is offline
AKA: Karan Hiremath
FTC #0110 (MFS Foxes)
alphadog0309 will become famous soon enoughalphadog0309 will become famous soon enough
you only get the 10 points for getting over if you end with your robot not touching any part of the ramp, bridge, or mountain. so using that strategy, you would get:
15 points from rolling goal
30 points from dispensing
15 points from balancing
15 points (possible if doubler is scored
______________________
75 points max
so far, by my calculations the most efficient way to score the max number of points would be to bring a goal over with you and try to score at least 3 loads of 5 batons
15 points from preloads
20 points from dispensing 10 batons
27 points from scoring 9 batons dispensed
42 points from scoring double baton
_________________________________________
119 points
but then again you only have 40 seconds
Unread 27-11-2010, 13:15
AKA: Nathan
Idealistically:
3*5=15 points from scoring preloads - 5 seconds to capture goal and score
10 points from being on other side - 15 seconds to go across and line up
That leaves 20 seconds to dispense and score.
2*15=30 points from dispensing 15 batons
3*15=45 points from scoring all batons dispensed
(2/3)*25-3=15 - probability of finding magnet baton
15+45+15=75 points from scoring doubler baton
15+10+30+45+15+75=
Maximum possible average autonomous score: 188 points - 40 seconds
Scored batons counted again after teleop - 154 points
Maximum possible average total score: 342 points + balancing
Wow. That's scary. I hope I miscalculated, because that's just ridiculous. Time to create blocking programs for autonomous.
SAY-WATT.ORG
Unread 07-12-2010, 02:56
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Our team, 3507 RoboTheosis, has this autonomous strategy:
1) We immediately engage and deeply entangle (not possess) the nearest rolling goal into a deep V-notch at front of bot which at full penetration of goal dumps five preloads into the furthest goal tube.
2) We easily navigate with the rolling goal well entangled into our deep V-notch at front, going over the tilt bridge to the other side, then arcing into and tracking along the far wall until we hit the side of the middle dispenser with a hard stopper that aligns our bot's side mounted vertical conveyor well centered on the middle dispenser.
3) We run our vertical conveyor to unload the doubler and as many more regular batons up our conveyor, which then directly dumps them onto a slide that guides them down by gravity feed into the three nearest tubes of the adjacent (in front) rolling goal .
4) We then retreat from our now well loaded rolling goal & head for the tilt bridge to balance
5) On start of teleop mode, we resume filling of the goal with the doubler in it to the max, then we bring the 2nd goal across to the 9" high dispenser and it is also filled directly by conveyor without moving the bot.
We always dispense & transfer directly into a well controlled rolling goal that penetrates 50% into the volume of our bot - without having to move from our position next to the dispenser.
-Dick Ledford
Unread 07-12-2010, 09:37
Joachim Joachim is offline
Joachim has a spectacular aura aboutJoachim has a spectacular aura aboutJoachim has a spectacular aura about
You must be emptying the center dispenser, then. Otherwise, why even go and try to balance?
Each additional doubled baton scored during autonomous equals 14 points by the end of the game (2 for removing from dispenser, plus 3 x 2 for autonomous, plus 3 x 2 at final scoring), while balancing only nets 5 additional points, relative to just staying parked on the far side near the dispenser.
Unread 07-12-2010, 09:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
-Dick Ledford
I will grant you that your mode will work for your first couple of qualification matches (and perhaps also against an elim opponent that isn't paying attention). However, there is an extremely simple autonomous counter:
Noob team 10001 creates a "drive straight for 1.5 seconds after a 5 second delay" autonomous. The robots collide. Your team gets only 25 points for position + rolling goal batons and a possible possession penalty if the timing is right. You may win auto mode by 10-15 points, however you've left yourself in the precarious position of having easy defense played on you for the rest of the match.
2017 Scoring Model
CAD Library | GitHub
Unread 07-12-2010, 11:43
AKA: Dick Ledford
Well with a high center that lets us easily traverse the mountain or either tilt bridge. 4-motor drive, the snow plow effect of the goal in front of us and more than one programmed route to the middle dispenser, the defense against up may not be as easy as you make it sound.
Of course we have anticipated this We are adding a 2nd conveyor on opposite side of bot now for this very reason - giving us more route options in autonomous mode. Plus we still have some serious scoring ability once the teleop mode starts, and we still have our goal fully entangled and ready to drive whereever we need to go next.
-Dick Ledford
Unread 07-12-2010, 11:48
AKA: Dick Ledford
We don't get all of them into the goal yet, but we do try to empty it, yes.
At least with the goal entangled and 50% penetrated into the space volume of our bot while dispensing, our speed at and odds of getting them into the goal is maximized.
-Dick Ledford
JesseK's Avatar
FRC #1885 (ILITE)
The point I was trying to make is that the center dispenser would be blocked. Your only recourse would be to go to another dispenser, which is not only less accurate but also (by definition of possession) causes you to lose the rolling goal.
2017 Scoring Model
Unread 07-12-2010, 12:00
TYour only recourse would be to go to another dispenser, which is not only less accurate but also (by definition of possession) causes you to lose the rolling goal.
The definition of possession of a rolling goal may not work the way you think, based on the official forum postings. Check out the thread on rolling goal possession.
Edit: The one here in this forum, that is: http://www.chiefdelphi.com/forums/sh...ad.php?t=87629
Last edited by Joachim : 07-12-2010 at 12:05. Reason: Add link to Rolling Goal thread
Unread 07-12-2010, 12:55
JesseK's Avatar
FRC #1885 (ILITE)
The updated ruling, only further affirms my interpreted definition of possessing a rolling goal, so the FTC GDC needs to update the manual with relevant info form the FTC forum postings. The rolling goal is moved forward with the robot and restricted from moving side to side at all. In Finals Match #5, 3539 even got the rolling goal off of a wall (the camera was turned away) well before the endgame.
The counter to the auto mode still stands though. I didn't mean to turn this into a legal issue about possession so much as the practical issue of containing the goal in auto mode. The 3539 driver maintained control without so-called possession because the driver stopped and started every time the robot turned. While an auto-mode could do the same on its own, it's next to impossible to predict what to do in a cluttered environment. Even worse is that the robot is then stuck next to an opponent robot whose driver will surely exploit the cluttered environment immediately (if the drive train is able...).
2017 Scoring Model
Unread 07-12-2010, 22:02
AKA: Dick Ledford
We don't approach the center dispenser from a 90 degree to the wall direction. We approach following the wall and can program select which side we come at it from. This allows us to push any blockers out of the way, because our all four wheel drive can move most blockers. Since our conveyor loads batons from the side of our bot and we always follow the wall to get into position opposite the dispenser, we are not as easy to block out from dispenser access as other bots are.
We can turn quite tight circles without loosing control of the rolling goal. The deep V notch and serious amount of entanglement with the scoring tubes makes it stay firmly in our control while turning tightly, and unless we back up at close to an angle 180 degrees opposite to our initial engagement path, we maintain very good control. It is also nearly impossible to knock it out of our control by any kind of impact coming from any angle.
-Dick Ledford
Unread 08-03-2011, 21:51
bpddpb bpddpb is offline
FTC #4299
bpddpb is an unknown quantity at this point
Sounds like our team (picklejarheads) does exactly what many people are mentioning: dump preloads, get over to the other side, dispense 15 batons. We save the doubler and 4 other batons, and then dump the rest on the ground.
15 points for preloads scored in autonomous
10 points for getting over in autonomous
30 points for dispensing 15 batons in autonomous
12 points for dumping 4 batons in TeleOp
15 points for preloads counting again in TeleOp
27 points for doubling 9 batons in rolling goal
10 points for balancing
119 points (just for one team)
We have our competition on March 12 and we're still working out the kinks in this idea, but we think it will work really well.
One of our earlier autonomous programs is shown on our youtube channel (picklejarheads)
Unread 14-03-2011, 17:03
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Hey...
That's a great Auto Mode G-FORCE could do:
Score 5 in rolling goal, cross bridge, Collect 5 from side dispensor and then go back and ballance.
15 + 10 + 15 (40 not counting points again at end of teleop)
Phil.
Originally Posted by team F.T.C 4240 View Post
Well you can score 55 points in auto mode if you score your 5 into the rolling goal (15 in auto mode) then go to the other side (10) then despence all 15 batons onto the floor [(30)you should save the doubler if you go for that despencer] and if you can somehow balance on the bridge then that would make it 60 points in auto mode.
(I tried to say an auto mode that is doable.)
thanks
Phil Malone
http://www.GEARSinc.org
Unread 20-03-2011, 08:38
FTC #4299
We also filmed a practice run in which we score the doubler baton:
http://www.youtube.com/watch?v=d25xJ...el_video_title
Autonomous Sentry Ideas 3DWolf Chit-Chat 3 21-07-2010 16:58
[FTC]: anyone have any ideas about next years game? BACONDUDE1902 FIRST Tech Challenge 7 13-05-2010 22:19
[FTC]: Autonomous? JohnFogarty FIRST Tech Challenge 32 12-03-2010 23:07
[FTC]: Autonomous saaby FIRST Tech Challenge 8 19-02-2009 12:45
[FTC]: Any ideas? ttldomination FIRST Tech Challenge 4 29-10-2008 11:41
