Go to Post We have to have a water-based game discussion each year, because every time I try to start up a "jello-based game" thread no one takes me seriously... - dlavery [more]
Unread 07-12-2010, 21:34
mattiej's Avatar
mattiej mattiej is offline
Programmer Guy
FRC #3413 (Mad Cows)
mattiej is an unknown quantity at this point
Re: Code Problems
Originally Posted by dmitch View Post
Ok sorry its been a while since i've been on. We smelled stuff burning last time we turned on our robot, so we took a further look and saw that several wires had slashes in them like someone had missed with the wire cutters...so we took apart all the wiring and are redoing it. (Yes that was serious.) And my question now is how on earth do you wire a PWM to a Jaguar? As i recall from my rushed intro last year the PWM can either hook into the sidecar or the cRIO slot??? And then go to either Jaguar or sensor??? (My knowledge on this part is REALLY fuzzy) I would prefer a diagram but if you have some words to post that will be very clear that would be great.
Sorry I don't have a picture. But what you do is use servo wires (Red, white, and black with three pronged push connectors) to connect the Jaguar to the Sidecar. The sidecar uses a serial (I think that is what it is called - it is really big) to connect to the cRIO. The Jaguar hooks up to the power supply via the red and black screws, and to the motor via the green and white screws. Hope this helps!
EDIT: Definitely use the diagrams above
Man pretending to be interested: "So how does this robot of yours work?"
Me tired of man pretending to be interested: "Magic. And Purple Yetis."
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Problems when combine ADC code && camera code nirhaim1942 Programming 1 24-01-2007 06:58
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
