Go to Post You know you've overdosed on FIRST when you set your alarm clock to your team # ex: 9:32 - bladetech932 [more]
Unread 12-07-2010, 09:42 PM
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: c-RIO connection troubles
As far as I know the only thing we needed to do to get the cRIO update working was remove the CAN plugin.
To reformat the cRIO, in the imaging tool you used to switch to Java, there should be a checkbox that says something along the lines of "Reformat cRIO". Check that and you should get a few more boxes available to select an image. If you have all of the programming updates installed on your computer, I believe the v20 image will be shown in the selection box. Make sure it is set to format to team #211 and language is Java (if you want to keep that).
Also, formatting the cRIO is equivalent to updating it. The only way to send an update to the cRIO is through a reformat.
With the switches the only one you really need to know about for this is the SAFE MODE switch. If you're still having troubles with this update, flip that and try again. Afterwards I believe you need to flip it back to off and perform the update a second time.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
c-RIO Blarglefish1255 Electrical 0 02-06-2010 03:11 PM
Extra C Rio? falconmaster General Forum 26 10-21-2009 05:14 PM
Lights On Compact Rio? excel2474 Electrical 13 01-24-2009 11:35 AM
Flashing compact rio? excel2474 Programming 3 01-06-2009 02:10 PM
RIO update? Betty_Krocker General Forum 3 12-03-2008 07:46 AM
