Go to Post The person that I would, without a doubt, would like to meet the most is my sanity. - lukevanoort [more]
Unread 07-12-2010, 20:07
team_hopeless team_hopeless is offline
team_hopeless is an unknown quantity at this point
Question Please Help Us, FTC Programming
Hey we are a newbie team and need some help programming in Labview, specifically with getting TeleOp Basic to run. We are using an older Field Control System and so are running the computer to the NXT brick with a USB cable. So far here is what we have done:
1) Opened the program TeleOp Basic that came in the templates folder.
2) Replaced the default Motor Configuration array with our own original TETRIX motor config.
3) Downloaded to NXT Brick. (Vers. 1.28)
4) Ran it on the NXT Brick and on computer w/controller.
Nothing happens! We had it running a few weeks ago just fine but all of a sudden nothing works. All suggestions are appreciated, and a huge thanks in advance!
Unread 07-12-2010, 22:19
PSHRobotics PSHRobotics is offline
FRC #1182
PSHRobotics is an unknown quantity at this point
Re: Please Help Us, FTC Programming
I recommend you post in the dedicated FTC sub-forum: http://www.chiefdelphi.com/forums/fo...play.php?f=146
But please make sure your wiring is correct. One key wiring component that is missed by many new teams is: make sure you connect the cable that goes from the NXT to the motor controller into the port that is on the side where "TETRIX" is written on the top of the controller. This seems to be shown the opposite in many diagrams and I have been told should not matter - but I have still seen programs spring to life when wired using that setup.
Unread 17-12-2010, 13:33
Gilgaern Gilgaern is offline
FRC #2925
Gilgaern is an unknown quantity at this point
According to the sole senior member of our team, most newer versions of the LabView program are incompatible with the NXT brick. Why not use direct/wireless connection of cRIO to a remote computer?
Unread 17-12-2010, 19:35
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
did you download program chooser to your NXT? It's in the Program Chooser 2.0 folder in your examples folder. After downloading it to the NXT, you must activate it on the nxt then use the NXT's arrow keys to select your Teleop program, then press the orange button twice. Otherwise the controller station won't know what to load. Hope this helps. Contact me if you have further problems.
"Don't worry, programming can fix it"
PROGRAMMING HELP PLEASE ! dcarswell NI LabVIEW 24 23-02-2010 22:57
[FTC]: Servo Help Please! Bluedog24 FIRST Tech Challenge 2 15-02-2010 20:31
Urgent Programming C++ help please! Tds123 Programming 5 25-01-2010 15:21
Programming help please?? programmr Programming 1 05-02-2009 11:40
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
