Go to Post Gotta love the use of universal technical terms, along with whatchamacallit, doodlespiel, whosiwhatsit... ;) - PaW [more]
Unread 07-12-2010, 13:34
Kett Captains's Avatar
Kett Captains Kett Captains is offline
Tired and Hungry
FRC #3098 (The Captains)
Kett Captains is an unknown quantity at this point
Problem connecting to cRIO
I am new to programming and networking as our programmer recently graduated last year. We are trying to set up a practice robot however every time we try to operate it displays a message, "cRIO not responding, physical reboot required." I have tried rebooting the robot and still nothing. Can someone please tell me how to fix this problem?
Unread 07-12-2010, 22:50
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Problem connecting to cRIO
If I'm reading your message correctly, it is the Driver Station that is giving you the message.
Can you ping the cRIO?
Have you imaged your cRIO?
Is there code on the cRIO?
If all of these are true, you may need to reformat your cRIO.
If someone else thinks differently, please correct me. This isn't an error I normally see.
-- Marshal Horn
Unread 07-12-2010, 22:51
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
That is not an error I remember seeing.
We will need more information to help. What are you trying to do? Program or drive it? Are you using the classmate or another computer?
If possible, post the steps you did leading up to the error.
Eric Haskins KC9JVH
Unread 08-01-2011, 16:39
Tired and Hungry
Problem solved, our electrical team connected the bridge to a different router not the radio. This caused the DS to give negative feedback as there was no way to connect to the cRIO. Thanks for replying
Connecting Solenoid to CRIO guitarbonham Pneumatics 6 06-02-2010 17:10
connecting to Crio using windriver Tds123 Programming 1 27-01-2010 13:21
Trouble connecting to cRIO? darty Programming 17 31-01-2009 16:15
Connecting to the cRIO lingomaniac88 Programming 1 30-01-2009 10:58
Connecting Axis camera to cRIO laultima FRC Control System 20 21-01-2009 16:56
