Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Unread 08-12-2010, 12:05
Re: Grey Jaguar No Power Out
I would think an analog voltmeter on the "DC" setting would do a reasonable job of measuring the effective DC-equivalent voltage of the Jag's PWM output.
Haven't actually tried it though. Anybody got data ?
You mean a Simpson 360 type meter? At best it might give you average readings for most of the higher throttle values. AT 50% or less, I don't think you could depend on it to give you any meaningful info other than the polarity and presence. The meter movement varies so much from manufacturer to manufacturer that I don't think you can make a blanket statement.
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
Power out puts ErinColleen Technical Discussion 2 21-01-2005 14:19
Grey Foam-Rubber Wheels RBrandy Technical Discussion 3 31-10-2003 01:11
Grey Daze Raven_Writer Chit-Chat 0 24-08-2003 18:45
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
