Go to Post Mentors need to be sure that the team is on track to have a working robot ready. Students can do almost everything, but they need help watching the calender. Even if your ideas turn out bad, if your robot is inspectable and running when you arrive at your first event, anything can happen. - AcesPease [more]
Unread 08-12-2010, 22:23
hg273's Avatar
hg273 hg273 is offline
AKA: Henry Gordon
FRC #1540 (Flaming Chickens)
hg273 will become famous soon enough
Re: Breakaway field should have been green
Perhaps you're referring to some of the off season events? Correct me if I'm wrong, but I was under the impression that FIRST does not supply the carpet for those, in which case you'd probably be seeing the gray carpets that most teams have.
Ooops...This should have been thought through better! phil-1302 General Forum 3 20-02-2010 18:44
[FTC]: parts that should have been made?? gregsanCHEVY121 FIRST Tech Challenge 12 13-01-2009 13:34
Ever been asked a simple question, that could have been answered with a search? Kingofl337 Chit-Chat 5 21-11-2008 08:35
Should all three pneumatics pistons have been received? Jordan A. General Forum 6 08-01-2002 13:48
Should the stretcher have been used more? Tom Fairchild General Forum 8 26-08-2001 02:40
