Go to Post Now, most of the replies are very tactful when they are questioning a teams' design... but some are simply stupid. Keep your heads. - Andy Baker [more]
Unread 08-12-2010, 23:20
Re: CIM/ Jag power help
Originally Posted by rahilm View Post
Just a regular digital multimeter. We have checked this whenever we have trouble and this is the behavior we see. (The multimeter is autoranging, so not range setting)
Does the meter have a setting for selecting DC or AC? If so, what setting was it on?
You don't happen to remember the brand and model number by any chance, do you?
Unread 08-12-2010, 23:21
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Yeah, we set it on DC.
I know it was a Fluke brand, not sure about the model number though. I can get the model number and confirm the behavior tomorrow. Maybe hook it up to an oscilloscope too.
Edit: Looking at Fluke's website, I'm fairly certain it is the Fluke 114
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 09-12-2010, 02:21
ErikRantapaa ErikRantapaa is offline
FRC #2532 (Flash Power)
ErikRantapaa is an unknown quantity at this point
A scope certainly would be able to tell you if the Jag is trying to drive the motors correctly.
I think it would be helpful to have a hand-held PWM signal generator to be able to test Jags directly. Something like this:
http://www.rc-cam.com/servotst.htm
or this:
http://www.sentex.ca/~mec1995/gadgets/servo3.htm
Also, any hobby store should have something similar available. Google for "servo tester".
Unread 09-12-2010, 15:49
or this:
Both of those say they go from 1 to 2ms.
I think the default input PWM range for the Black Jag is 0.67 ms to 2.33 ms.
So those devices wouldn't drive a default-configured Black Jag's output to its full range.
Name:	Jag input.png
Jag/ CIM compatability problem team3329 Technical Discussion 1 08-12-2010 15:10
Help: Bevel Gear Mounted On CIM Shaft? 854 bears Motors 16 24-07-2009 13:50
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
cim motor power question Zippiot Motors 16 16-02-2005 20:40
