Go to Post The minute you get a functioning mechanism start working on a better one - [more]
Unread 08-12-2010, 10:19
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: strong composites for belly pan
Just to throw another idea in there... what about making the bellypan in pieces? With out design last year, our pan had to be pretty deep to hang off the frame like we wanted. As a result, we couldn't make it out of a single sheet of aluminum - we ended up bending up two sheets, and pop-riveting them together down the middle of the robot. It worked great, and was plenty strong. So if you can work smaller pieces of aluminum and build the pan out of 2-3 sheets instead of one, that could be a viable alternative.
Unread 08-12-2010, 10:38
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
A couple ideas:
Carbon Fiber with balsa core.
Carbon Fiber with honeycomb core.
Fiberglass with balsa core.
You can find almost any composite/core combination you'd like. We used a piece of fiberglass/honeycomb core for our 2005 robot electronics board. It is very stiff, light, and strong. Can be a little pricey though. Taking the 1/2" balsa-cored carbon fiber as an example, it has a density of 0.0125lb/in^3, about 88% less dense than aluminum.
If you get a little ambitious you could make this sort of stuff yourself, it's not terribly difficult.
Unread 08-12-2010, 11:49
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Any thoughts on perforated plastic sheet (e.g., McMaster-Carr 9293T56)?
--Madison--
...down at the Ozdust!
Unread 08-12-2010, 12:00
I don't know about perforated plastic sheet, but corrugated plastic is fairly strong and fairly light. If it's properly supported (around the bottom of the frame, say) it can hold a full-weight robot. I don't remember what thickness we used on our ramps in 2007, but I don't think it was more than about 1/4"-3/8", on about a 3' square.
Unread 08-12-2010, 12:57
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
In case honeycombed composites are considered...
Our electroncs boards have been made from honeycombed fiberglass made by PlasCorp since 2007. The combination of a stiff board, insanely light weight vs. square footage, and insulating factors made it ideal for us to use. We even mounted the compressor and battery on the material for 2010.
The material is somewhat easy to cut with hand tools, but I would recommend a table saw and/or band saw. It is extremely easy to drill through, and not too difficult to punch through with a hand punch + hammer. Finally, spraypaint works great for color.
However, I would not recommend using it for a belly pan that provides support to the frame. The gaps from the honeycomb structure are not strong enough to withstand the implied lateral forces. I also recommend against mounting the board vertically unless the bottom edge has a lateral support since gravity will have the same lateral-force effect.
GitHub
Unread 08-12-2010, 13:27
svenw svenw is offline
FRC #3683
svenw is a jewel in the roughsvenw is a jewel in the roughsvenw is a jewel in the rough
You might ask yourself if the belly pan needs to provide rigidity, or if it just needs to house electronics. In the past years, we have always used a box al welded frame and 1/8" lexan. The frame is solid without the lexan.
Because this is our first year welding aluminum we would like the belly pan to provide a bit of support incase our welds are not as strong as they should be. We are welding with our schools millermatic 180 with a spool gun for aluminum, and have been getting some fairly decent welds, but not perfect.
As per your techno, if it is similar to the new one we got here, it can cut aluminium using a carbide endmil
We actually had these guys cut on a 4x8' Techno Router
I figured that the router would be able to handle aluminum, and have been talking about it to our shop teacher about it. Apparently our school board is scared that the school might catch fire if we use a "wood working" tool to cut aluminum, we might just have to do it late on night when no one is around .When routing aluminum do you use 6061 vs a 5052? I think i read somewhere that routing a harder aluminum works better because it does not gum up the router bit.
carbon/s2 glass plywood panel for a robot bottom can be done for relatively cheap
We actually do have a bit of experience working with carbon fibre, we purchased a vacuum pump as well as a sheet of glass, and made some side panels out of carbon fibre last year. It was fairly brittle however, but this could just be because we did not do enough layers, how many layers of cloth would you recommend, and what exactly is S2 glass?
corrugated plastic is fairly strong when pushing it in the right direction, however when you push on it from the side would it not fail fairly easily?
Sven
Unread 08-12-2010, 14:00
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
We have routed 1/8" 5052 al plate and 3/4" 6061 aluminum. 6061 clearly machines easier, but 5052 can be machined too.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 08-12-2010, 15:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
If you decide to lay up your own panels the number of layers will be determined by the weight of weave you use, the type of weave you use, the type of material (carbon, kevlar, glass, blended, etc).
For a good mix of aesthetic, coolness, and strength I would use something like this colored/blended fabric and do either 5 layers alone, or 2-3 layers on top and bottom of a core material (just from the seat of my pants) and definitely use epoxy for the medium. Don't forget to do a multi-angle layup.
Unread 09-12-2010, 18:46
DonRotolo's Avatar
Back to humble
FRC #0832
You mean they should cut up a pair of your pants? Hopefully not while you're still wearing them...
Seriously: Good advice. A lightweight but low-compressibility core will enhance the stiffness of the layup by bringing the tensile fibers (fiberglass or kevlar) further from the center of bending. Balsa is good, high-density styrofoam (expanded polystyrene) works very well, even 1/4" luan plywood is good. 1/8" is a good thickness to experiment with.
We've made some experimental layups using 1/16" aircraft plywood and 2 layers of 3 oz fiberglass, laid up at a 45 degree bias using marine epoxy and pressed tightly for cure using a heavy weight (iron barbell weights), the stuff was incredibly strong. Only problem is finding large sheets of 1/16" plywood, we used small pieces made for the hobby market.
Unread 09-12-2010, 20:48
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Originally Posted by Chris is me View Post
Lexan can be used for an electronics belly pan at 3/32 or 1/8th. However, unlike an aluminium belly pan it won't provide much structural reinforcement / rigidity to the chassis, as lexan is very flexible.
1/4" polycarbonate can be used, and will work for mounting of electronics. It's thick enough that it can be tapped and can be heated, bent and hold it's new shape.....plus won't shatter on impact.
Not good for heavy assemblies mounted to it but it may work for a basic belly pan/skid plate set up.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 10-12-2010, 08:34
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Thanks. Have you ever used those plates on your robot? It does sound like very durable construction.
OP, FWIW: typical commercial wood-cored composites orient the wood grain normal to the surface of the plate, typically called "end grain" orientation. This orients the core in a way to take maximum advantage of it's shear strength, the skin will support tensile/compressive loads.
Unread 10-12-2010, 09:22
Mike Q.'s Avatar
Mike Q. Mike Q. is offline
AKA: Mike Quick
FRC #0085 (B.O.B.(Built On Brains))
Mike Q. will become famous soon enough
I may be a little bias because they are one of our sponsors, but plascore is some pretty cool stuff. http://www.plascore.com/
FRC team 85: Student (2007-2010)
FLL: Mentor (2008-2014)
FTC team 10255: Mentor (2015-Current)
pan/tilt connection for 2007 camera kasemodz Programming 5 21-01-2007 14:21
Team 104's succcessful use of composites Gdeaver Technical Discussion 9 05-03-2005 21:40
Graphite Composites Odlaw Kit & Additional Hardware 6 26-01-2005 08:18
pic: IRI 2003 Belly Check CD47-Bot Extra Discussion 17 24-07-2003 16:49
Composites Simon G Technical Discussion 2 18-01-2002 01:43
