Go to Post I've always suspected that one could find glimpses of wisdom, setting priorities, and responsibility - and ways to balance them, in the contents of a coffee cup. - JaneYoung [more]
Unread 10-12-2010, 23:26
jspatz1's Avatar
Happy Birthday! jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Bimba Spring Supershifter Piston
The cylinder will consume no air after it is extended, the pressure holding it is static. You will want to maintain extend pressure (valve actuated) so the holding force is maintained. When retracted (valve exhausted) the cylinder will be vented and the spring will supply the only return force. A spring return cylinder consumes 1/2 of the air (actually a little more than 1/2 due to the rod volume) of a double-acting cylinder.
Spring loaded Pneumatic piston Team2191 Technical Discussion 17 15-01-2010 23:51
AM SuperShifter in Inventor ADZDEBLICK Inventor 17 02-01-2008 05:25
Nut for Bimba Piston chris31 Pneumatics 6 29-07-2007 21:30
spring piston Matt21q General Forum 2 02-02-2007 23:44
spring piston? Matt21q Technical Discussion 2 02-02-2007 17:02
