Go to Post A FIRST fanatic who never had any desire to be an engineer. There. I said it. ;) - Katie Reynolds [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Unread 11-12-2010, 13:52
Cookies Cookies is offline
FRC #1075
Cookies is an unknown quantity at this point
Canbus pros and cons
Hi. im just wondering wat the major pros and cons for a canbus are. a list wud greatly be appreciated. =) thank you
Unread 11-12-2010, 14:49
Re: Canbus pros and cons
What pros and cons have you already found from your own research?
Unread 11-12-2010, 17:25
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
One indirect advantage of using CAN is that you can take advantage of the intelegence built into the Jaguars. For instance, you can set up the Jag to perform the PID control of a system rather than having the cRio manage that process. That frees up the cRio to do the Jag can't do, things like image processing.!
Unread 11-12-2010, 18:15
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We found that it made the wiring much simpler and neater. Just be sure to get a good crimper, extra ends, and absolutely test every wire made both physically and electrically.
A down side is if one of your wires fail, the whole bus fails.
Here's our e-board from 2010. 8 Jags on a two sided lexan panel. Just plug it in and go. Something we are considering for this year is maybe adding some strain relief to the connections as a precaution. Here's a better pic..
Unread 12-12-2010, 09:02
diviney diviney is offline
FRC #2377
diviney has a spectacular aura aboutdiviney has a spectacular aura aboutdiviney has a spectacular aura about
Nice board, but how did you pass inspection without a main 120A breaker (elsewhere on the robot with a 2nd Anderson connector to the e-board I hope?)
Unread 12-12-2010, 19:16
Doug G's Avatar
Coach / Teacher
You got it right! We had the main breaker mounted on the robot and connected with Anderson connectors . We also had a motor connecter bus which you can barely make out in the pic. Just plug in motor connection and sensors and the main connector and we were done.
Unread 12-12-2010, 12:59
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
In addition to being to use the Jag's intelligence to actually control the motors, being able to use them for diagnostics is pretty handy as well.
We used them to check out our motors and gearboxes, and when there was a problem, it was much more convincing to be able to say "this motor is drawing 10x the current to go the same speed" vs "this does not sound right". It turned out that a Super Shifter gear was accidentally assembled into one of our Toughboxes.
The only cons I believe stemmed from the technology being new (CAN IDs would randomly reset, the C++ library was a bit buggy and was rereleased too many times during the season IMO), but I don't expect to see these problems again.
Overall, you can do everything that CAN provides other ways, but it is very nice to have everything in one place. I would recommend it.
6WD Pros and Cons ChuckDickerson General Forum 59 13-01-2008 02:20
Kitbot pros and cons Jaybee1405 Kit & Additional Hardware 16 06-01-2008 23:57
Pros and Cons of Using Pneumatics Joe_Widen Pneumatics 22 30-06-2006 10:16
Two cameras: Pros and Cons cooknl Programming 1 12-01-2006 20:57
Timing belts pros and cons!!!! archiver 2001 3 24-06-2002 00:33
