Go to Post I wish my biology class was this exciting. - MissInformation [more]
Unread 11-12-2010, 14:00
Re: Grey Jaguar No Power Out
I tested with a globe motor load and the oddity disappears, so the odd collapsing waveform and the 2v drop seems to just be a characteristic of the adaptive gate Al brought up and the lack of a load as Alan suggested. It shouldn't affect normal operation.
There was a .15v drop through the Jag at 100%, but my battery is down a bit so that's not a full measurement.
The gray/tan jag gives full power at 100% with a load, and 2v less without a load.
With a load the waveform is the typical duty cycle switching between 0 and battery voltage for increasingly longer times as the throttle changes.
The CIM and the window motors show a cleaner 100% than the globe motor for some reason. Up to 100% everything about the power output waveform is identical. At 100% I see the periodic tiny drop to 0v on the CIM and Window motors, but for the globe the scope displays a messier plot.
The CIM also drew the battery down a bit more than the others of course.
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
Power out puts ErinColleen Technical Discussion 2 21-01-2005 14:19
Grey Foam-Rubber Wheels RBrandy Technical Discussion 3 31-10-2003 01:11
Grey Daze Raven_Writer Chit-Chat 0 24-08-2003 18:45
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
