Thread Tools |
Rating:
Display Modes |
Re: Canbus pros and cons
What pros and cons have you already found from your own research?
One indirect advantage of using CAN is that you can take advantage of the intelegence built into the Jaguars. For instance, you can set up the Jag to perform the PID control of a system rather than having the cRio manage that process. That frees up the cRio to do the Jag can't do, things like image processing.!
We found that it made the wiring much simpler and neater. Just be sure to get a good crimper, extra ends, and absolutely test every wire made both physically and electrically.
A down side is if one of your wires fail, the whole bus fails. Here's our e-board from 2010. 8 Jags on a two sided lexan panel. Just plug it in and go. Something we are considering for this year is maybe adding some strain relief to the connections as a precaution. Here's a better pic.. Last edited by Doug G : 11-12-2010 at 18:16. Reason: added link to hi-res pic |
You got it right! We had the main breaker mounted on the robot and connected with Anderson connectors . We also had a motor connecter bus which you can barely make out in the pic. Just plug in motor connection and sensors and the main connector and we were done.
| 6WD Pros and Cons | ChuckDickerson | General Forum | 59 | 13-01-2008 02:20 |
| Kitbot pros and cons | Jaybee1405 | Kit & Additional Hardware | 16 | 06-01-2008 23:57 |
| Pros and Cons of Using Pneumatics | Joe_Widen | Pneumatics | 22 | 30-06-2006 10:16 |
| Two cameras: Pros and Cons | cooknl | Programming | 1 | 12-01-2006 20:57 |
| Timing belts pros and cons!!!! | archiver | 2001 | 3 | 24-06-2002 00:33 |
